Old 01-02-2004, 03:17 PM   #1
taser
stamped codes on front end???
i just picked up a new disc brake front end...is there any where on it i can find the gear ratios stamped or codes, or do i have to count the teeth...all i found was the 44 thanks - todd
taser is offline   Reply With Quote
Old 01-02-2004, 04:34 PM   #2
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
ear ratio for the rear end?
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-02-2004, 06:56 PM   #3
Blazer1970
Blazer1970's Avatar
The BOM number is stamped on the front side of the drivers side axle tube starting a couple of inches over from the center section. A Dana/Spicer dealer can tell you the original application and ratio from that number.
Blazer1970 is offline   Reply With Quote
Old 01-03-2004, 02:19 AM   #4
taser
i found this site, thought it might help some of ya
http://www.melanchete.com/bob/dana_axle_ident.htm
Old 01-03-2004, 09:26 AM   #5
Blazer1970
Blazer1970's Avatar
You can also get that info at the Dana Corp. web site. The problem is tht they both only go back to 1979 or so. If you want to decode the older numbers, you have to find a Dana Spicer dealer that keeps their old books.
Thread Tools
Display Modes
