Old 08-16-2022, 08:45 AM   #1
1979_chevy_4x4
Aftermarket Tach
Hi I bought a 79 k10 all original with a 350 backed with a sm465 transmission. Since I want to preserve the originality I don’t want to take the cluster apart and swap tach that way. I would like a tach for the matter of I’m wanting to keep an eye on the rpm to not be beating on it but also get where I need to go without risking taking it too far. What type of tach to use and where to mount?
1979_chevy_4x4 is offline   Reply With Quote
Old 08-19-2022, 09:14 AM   #2
Axle
Axle's Avatar
Re: Aftermarket Tach
Autometer 2300 series is my goto. Hose clamp in clear tubing, mounted to the steering column at the edge by the steering wheel. Doesn't damage anything, no screw holes in anything.
Axle is offline   Reply With Quote
Old 08-20-2022, 02:50 PM   #3
Pontiac1976
Pontiac1976's Avatar
look up AutoMeter Tach or there cheaper line AutoGauge for one you like. (Style and size). As said a dry 5-6 " clamp make sure you put the clamp on the (column) part that does not turn when shifting, some time you may have to make up your own Z shape bracket to get the right placement for height.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Thread Tools
Display Modes
