Old 09-14-2022, 12:44 PM   #1
hairdog
Clever ways to put washer, lock washer, and nut on bed bolts
I am at the installation phase of my 1966 C20 bed wood and rails. I was wondering if any of you folks have figured out a clever way to fit the washer, lock washer, and nut onto the bolt. My fingers must be fat because I have trouble fitting them and the two washers up into the channel, then holding them up there until I can also get the nut into the channel and get it threaded onto the bolt.
I have toyed with the idea of super-gluing the nut and washers together but there probably is a better way.
hairdog is offline   Reply With Quote
Old 09-14-2022, 01:00 PM   #2
61hawk
61hawk's Avatar
Re: Clever ways to put washer, lock washer, and nut on bed bolts
Grease works in holding everything together.
If you're using the stainless steel nuts and bolts, use anti-seize to keep the threads from galling, because the only fix is to snap the bolt if it happens.
61hawk is offline   Reply With Quote
Old 09-14-2022, 02:06 PM   #3
LVPhotos
LVPhotos's Avatar
X2 on antisieze for SS. I use wax at work for store fronts. So if you want a clean surface the wax will melt away instead of grease
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-14-2022, 08:28 PM   #4
geezer#99
geezer#99's Avatar
I’ve used grease to keep washers in place.
For tight spots that a socket wouldn’t fit on I used a box end wrench with a piece of tape across the opening to keep the nut trapped in place.
Thread Tools
Display Modes
