![]() Join Date: Jan 2013
Frame swap 64 2wd C20 long bed to a 71 C20 frame
what are the problems in mounting a 64 GMC cab, nose, and 8' bed onto a 71 or 72 Chevy frame? or is it easier to add front disc brakes and power steering to the 64 frame? all opiniones appreciated, thanks
Re: Frame swap 64 2wd C20 long bed to a 71 C20 frame
I would never frame swap for disc brakes. Lots of info on here about it
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
Swapping disc and power steering are pretty straight forward on the earlier frame. I know some GMC trucks had rear leaf springs and I could see that being one factor for swapping the frame, but aside from that it would be easier to swap the front crossmember and get a power steering adapter such as those made by Captian Fab. If you have a donor lined up your already on your way. Don't overlook the rear end too because the donor may possibly have a more favorable gear ratio.
I had considered getting a 64-66, so I have a complete rolling c20 chassis from 1976.
Still haven't got my 64-66 though. |
![]() ![]() ![]() Join Date: Jan 2018
Definitely easier to swap over the front suspension since the front crossmember is almost a bolt in with just drilling a couple holes. The cab on the later frame requires modifying the cab mounts and you run into issues with the front bumper and frame horns not matching up correctly
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Front frame horns are shaped different so changes are required depending on bumper used.
Front radiator core support mounts are in a different location. Rear cab mounts are in a different location. Definitely easier to swap disc brakes & power steering over to a '64 chassis.
Thread Tools | |
Display Modes | |
