11-07-2022, 10:11 PM | #1 |
Power Steering Hoses
I have all of the parts for my power steering. I mounted the pump on my 350 SB and now I need to get some hoses so I can finish the installation. What hoses are y'all using? This is for a 65 C-10.
John Wilson |
11-07-2022, 10:41 PM | #2 |
Re: Power Steering Hoses
What year pump and steering gear are you using? Some pumps and gears have flared fittings for the lines, others use o-rings. Hopefully you won't have to have custom lines made
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-07-2022, 11:22 PM | #3 |
I think it's around a 74 pump and gearbox. It doesn't use o rings.
John Wilson |
11-09-2022, 12:35 AM | #4 |
I believe you can just use 74 lines as well
11-09-2022, 08:41 AM | #5 |
Thanks guys. I did some more research and ended up purchasing 68-9 Camaro hoses. They look like they will work out fine. I haven't installed them yet but they fit all of the fittings on the pump and gearbox.
John Wilson |
Thread Tools | |
Display Modes | |
