Old 02-23-2023, 12:43 AM   #1
rhamer88
1984 Wiper Issue
Evening all! Having an interesting issue with my wipers on my 84. I’m searched and searched though old posts and couldn’t find anyone with the exact same conditions as I’m having.
Anyway, the issue is the wipers won’t park 90% of the time. They just stop where they are when I turn them off. Sometimes if I leave then where they are after I turn them off, they’ll stay still for about ten seconds and then return to park. I’ve replaced the motor (twice) and the switch in the steering column.
Any ideas or things to try?
rhamer88 is offline   Reply With Quote
Old 02-23-2023, 10:24 PM   #2
ray_mcavoy
Re: 1984 Wiper Issue
Since you have replaced the wiper motor (which includes the parking switch) twice, it seems unlikely that the parking switch itself is at fault. However, the wiring that goes to the parking switch might have a poor / loose connection.
The most likely place for that to occur would be at the plug on the wiper motor. The one for the parking switch is the 2-wire plug up on the gearbox end of the motor with the gray and black w/ light blue stripe wires. Try wiggling that connector to see if it makes a difference. If so, you might have to replace the terminals inside (or try carefully bending them a little with a pick so they make better contact).
ray_mcavoy is offline   Reply With Quote
Old 02-23-2023, 11:05 PM   #3
TKCR
TKCR's Avatar
I have had this problem also. The research that I have done lead me to the wiper module. I had replaced the switch on the steering column but that did nothing, still had the same issue. But once I replaced the module I haven’t had any issues.
Old 02-24-2023, 12:12 AM   #4
rhamer88
Ahh that’s great advice! That points me in a new direction I hadn’t considered. Thank you for that!
Old 02-24-2023, 12:13 AM   #5
rhamer88
Another great piece of advice! Thanks for the picture with the part number. I’ll look into that as well. Where exactly is that located in the truck?
Old 02-24-2023, 08:09 AM   #6
Pontiac1976
Pontiac1976's Avatar
I assume that TKCR and rhamer88 are working with pulse wipers option I did see that if you both had that option or not. I do not have that option have not seen that part on the steering column. Very Kool info. .
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 02-24-2023, 09:47 AM   #7
TKCR
TKCR's Avatar
Sorry rhamer88, I just realized you said you have an 84. These parts are for the 85 and up.
Old 02-24-2023, 06:27 PM   #8
rhamer88
Yea I was looking around last night and figured out that picture you posted was for pulse wipers. I wish I had pulse wipers, quite the convenient upgrade! Thank you for sharing though…that’s what this hobby is all about.
Thread Tools
Display Modes
