10-10-2023, 11:05 AM | #1 |
Door Glass Channel Parts
Having trouble finding the felt/rubber channel that fits in the Channel-Door Glass-Rear- pieces, these are for the rear of the glass to slide up and down in. There is a felt/rubber piece, which is the channel, that the glass fits in. My actual metal pieces are just fine, I only need the felt/rubber piece that fits in the metal channel.
Or do you have to spend $140 bucks + to get the entire metal pieces, which I would think then include the felt/rubber channels? In pics is the piece I'm looking for without any luck. |
10-10-2023, 12:05 PM | #2 |
Re: Door Glass Channel Parts
GMCPauls.com sells the "Glass Run Channel" individually for $15 each.
https://gmcpauls.com/Pickup.htm It's the third item from the bottom. |
10-10-2023, 12:29 PM | #3 |
I just installed a new set of these on my truck from classicparts.com https://www.classicparts.com/1967-72...ctinfo/03-317/. I had them installed within minutes and they fit great.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
10-10-2023, 02:13 PM | #4 |
The piece in your pic looks like the rear glass run channel. The previous post is the correct felt. The felt is one piece that goes into window frame on door starting at vent window all the way down that channel. The front channel is part of the vent window. The felt that goes there is separate and one straight piece. Also available at classic parts.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
10-10-2023, 03:02 PM | #5 |
Great, thanks guys, valuable info. I'm going to get GMC Pauls, that looks like the correct felt/rubber that I need.
Thread Tools | |
Display Modes | |
