Old 01-12-2004, 06:21 PM   #1
TIMSPEED
TIMSPEED's Avatar
Think I found my bad idle problem: Blown EGR Valve Gasket
Well, today when I was looking around my carb. I had a friend rev it while I watched for anything...BINGO! When my friend would rev it, it would blow smoke out around the EGR Blockoff plate. So I'm gonna throw on a new gasket with some sort of sealant (Can't I use just high temp permatex?)
Hopefully it'll cure the idle problem...
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 01-12-2004, 07:27 PM   #2
apstguy
LED King
apstguy's Avatar
You don't need any sealant. If it has a riser block like mine you will need two new gaskets, not just one. Tighten it down & it won't leak. It is metal reinforced.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 01-12-2004, 07:32 PM   #3
TIMSPEED
TIMSPEED's Avatar
hey buddy, I want it to STAY SEALED FOREVER!
Well, it's an EGR Blockoff plate, so it's just an actual piece of 1/16th" Metal Plate, But I'll put two (the blockoff plate came with just one gasket)
See Them Here
Old 01-12-2004, 07:33 PM   #4
apstguy
LED King
apstguy's Avatar
If it is a block off plate just use one. Two is just another seam to leak. The metal in the gasket will make the gaskets not conform to eachother.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 01-12-2004, 07:40 PM   #5
TIMSPEED
TIMSPEED's Avatar
Well, it's leaking...so I'm gonna do something...
See Them Here
Old 01-12-2004, 10:02 PM   #6
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Tim,
Use just one gasket and get some loctite black RTV sealant and dont over tighten the bolts.
That block off plate you have now is too thin it should be no less than a 1/4" thick so it wont warp in the center when you torque the two bolts.
And some lareg area flat washers under the bolt's would help as well.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-12-2004, 11:07 PM   #7
TIMSPEED
TIMSPEED's Avatar
It all came in a kit...
See Them Here
Thread Tools
Display Modes
