Fan clutch on a 292?
I’ve got an ancient aftermarket flex fan on my 65’s 292. Had one come apart on my old Mustang years ago and figured I’m pushing my luck with this one in my truck.
I’m not interested in any kind of electric fan (I like simple). Was considering a fan clutch with maybe some kind of plastic fan. Anybody do anything similar? I’m running an aluminum Champion brand radiator, but no shroud, as apparently nobody makes one for this application Getting ready for summer, any advice? Thanks, Tom
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear |
Re: Fan clutch on a 292?
If you have the space, a clutch + a 5 blade metal fan from a SBC might do the trick. Unless you have an overheat issue, get the standard duty clutch.
I believe my fan setup to be factory and there is no clutch. The fan is fixed and always turns at engine speed.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
A clutch & 7 blade fan for a small block will work if you have a 2 groove harmonic dampner. It will not clear a 3 groove. However the 292 I currently have in my truck came from an 85 K20. It has a 3 groove dampner & three blade clutch fan. It's the only three blade clutch fan I have ever seen. Every other one I have ever really looked at was 5 or 7.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
![]() Join Date: Nov 2013
I used a new Hayden 2705 clutch and Derale 17119 fan On my 64 with a 292. The fan matched the diameter of the original and the clutch was about the same depth as the fan spacer that came on my truck
Appreciate all the input, I figured I wasn’t the first to try this. Fortunately I have the two groove damper, so that should make things easier.
Thanks, Tom
Thread Tools | |
Display Modes | |
