05-28-2024, 07:31 AM | #1 |
Junior Member
72 ck 20 paint code 51410 (med red)
This is the original paint from the factory. Almost could be a mix of the red and hugger orange
Anyone else use this paint ? And is it a 2 part base paint ? % using 2 part sealer primer vs hi build Thank you guys |
05-28-2024, 12:37 PM | #2 |
Re: 72 ck 20 paint code 51410 (med red)
In '72 it most likely, would have been a single stage. Today, most likely it would be sprayed as a base/clear. But a 2k single stage is also perfectly acceptable. If that's what the customer wants.
A 2k (2 part ) high build, is a catalyzed primer/surfacer for use in the bodywork stage. A 2k ( 2 part ) catalyzed sealer. Is used in the painting stage. To provide a uniform base color, and a chemical bond between the base color and the final sanded substrate. Depending on brand and the exact product,. There are some 2k primer/surfacers that can be sprayed as a high build,medium build, and sealer. Generally speaking . . . Last edited by Grounded63; 05-28-2024 at 12:52 PM. |
05-29-2024, 10:00 AM | #3 |
Junior Member
Grounded . That's GREAT INFO that will go A LONG WAY in my restoration of my dads truck
I remember driving home with from the dealer with it. I plan on now going your route with both 2k primer types you mentioned. I finished 2 restorations on 2 motorcycles which required no paint and good ole "BIG RED" gets it's long overdue love . ZERO MODS "except a intake, carb, 9:1 flat top pistons " Everything else stock stock stock Rg500gamma |
05-30-2024, 12:30 AM | #4 |
Post Whore
ive been using sherwin williams single stage paint..im well pleased with the results
also used their epoxy and high build primer, but ive now gone to SPI primer
Thread Tools | |
Display Modes | |
