Painting the cab
I am getting pretty close to painting the cab. I have to finish final sanding and then I plan to seal everything with a thinned epoxy (eastwood) followed by single stage paint. As I am doing the entire cab inside and out the same color, should I paint it in stages (inside first, let it dry, then outside)? Or should I do the entire thing all at once?
Thanks, Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
Re: Painting the cab
I would definitely break it up in stages. Paint the inside. Then back mask and seal the window openings and door jams, at the pinch welds.
That makes sense. Would it be better to only seal the inside, paint that, back tape the cab and then repeat for the outside? IOW, only seal what I am painting at that time?
Yes, generally you let the sealer flash then then go right to paint. The tech sheet should give you the specs for that. Depending on the product, you will have a window by when you need to start spraying the top coat by. Or, you will need to re-sand the sealer, and start over.
As said above interior first and then back mask. Then the outside. That way you won't be dragging an air hose across new paint to get at the interior.
Ok, thanks everyone! Hopefully I can get this thing in some color soon.
Clay
What color are you painting it ?
Are you also using Eastwood single stage paint. If not, I would recommend using that paint manufacturers sealer. |
#8 | |
Clay
Sounds great !
Thread Tools | |
Display Modes | |
