06-04-2024, 10:25 AM | #1 |
electric fan conversion/heater hose question
For my 68 C10, I'm considering converting my 1990 tbi 350 to an electric fan, but my motor doesn't have a water pump heater hose inlet, and so I have the return heater hose connecting to the top of the radiator next to the battery instead. My radiator is from a late 70's square body. None of the radiator/electric fan conversion kits I see have an upper hose inlet on the right side near the battery. Does anyone know of a workaround for this? I think I read somewhere about a spacer under the thermostat with a nipple attached. Would that work in lieu of connecting to the radiator?
06-04-2024, 11:19 AM | #2 |
Re: electric fan conversion/heater hose question
I think you are looking for something like this? It is a Campion kit.
06-04-2024, 12:08 PM | #3 |
06-04-2024, 03:09 PM | #4 |
I may be missing something but are you just wanting a radiator with a heater pipe? My '83 K20 had that as stock with the 350 version of the radiator. Then I upgraded to a 454 radiator and it still had the heater hose inlet. They are also available with oil cooler provisions. I have dual Corvette C4 fans on mine
(see https://www.corvetteactioncenter.com...bfh/bbfh7.html) I have TunedPort fuel injection on mine so the ECM controls both fans. If you have TBI I believe you can control at least 1 fan with that ECM. Alternatively you could use a BMW sending unit with a Volvo relay to control a 2 speed fan. (see https://www.therangerstation.com/tec...tric_fan.shtml)
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-04-2024, 03:15 PM | #5 | |
06-05-2024, 07:48 AM | #6 |
If you leave the water on the radiator you get warm water for heat faster in Winter. It's kind of nice if you use the heat much.
06-05-2024, 08:00 AM | #7 |
Thread Tools | |
Display Modes | |
