Add Cruise Control to 68 Suburban
Looking to add some kind of cruise control to my 68 GMC K15 Burb. Truck has 327/TH350 (well I'm assuming a TH350). Wanted to use the Rostra turn signal/cruise lever #250-3020. Using this lever, what else will I actually need to make it work?
https://www.amazon.com/dp/B008LUTF0C...607340_TE_item Last edited by DBear; 06-12-2024 at 10:39 PM. |
#2 | |
The Older Generation
Re: Add Cruise Control to 68 Suburban
Hi Tommy, If you scroll down on the page with the lever it lists a Rostra cruise control unit. If you click on that it tells a little bit about it and what other pieces you will need to make it work. I think I would use the matched components because the Rostra lever works the opposite of a stock GM lever as far as the electrical components.. .
#3 | |
I actually talked to Michael at M&R Electronics today. They specialize in cruise control systems. He definitely knows his stuff. Keep in touch buddy! |
#4 | |
Good deal! I am doing well & I will keep in touch. Thanks....
Thread Tools | |
Display Modes | |
