Roto Reuter thats the name...
![]() Join Date: Feb 2010
WTB Door Latch Relay Mechanism (regulator)
Looking to buy LH Driver Side door handle mechanism for 71 C10. I will take both LH & RH if they are both in really good condition. I'd rather not take a chance on aftermarket
I believe these would have to be from 68-71. I know at least that '72 is a one-year only. I only need the handle mechanism. Let me know what you have. Thanks.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
![]() Join Date: May 2003
Re: WTB Door Latch Relay Mechanism (regulator)
Let me check, I have several but need to see what side and what condition.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
This is what I have, don't know for sure if its OEM or not. Spring is good.
I also have the matched pass side also. Look the pictures over and see what you think. Gary
Do you know what year these were out of? Also, would you please double check the springs closely on both LH & RH units? For some reason I was thinking that the spring wrapped around that square tab that sticks up. I can't confirm because the one good unit I have is installed in the truck.
There's are correct for 68-71 but I don't know what specific yr they came out of.
It's been 40yrs of messing with these trucks and they were in a box with several others. I do have some good 72s including an NOS 72 I can compare them to. Gary
Here are a couple better pictures showing how the springs attached.
Both are not broken and are strong when moving the lever. I believe there probably was more than 1 vender that supplied these to GM, because I see subtle differences in how these are made. Maybe someone on here can helps us out as to tell if the OEM or not ? Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 06-16-2024 at 08:27 AM. |
Thanks Gary for the close up pictures. Let me know what you want for each (driver side & pass side).
I'm thinking $45 for both to your door.
Gary
OK, I think that will work. I will PM you my contact information. Please let me know how I can pay you.
Payment has been sent. Thanks Gary.
Ok, there boxed up and ready to go.
Thread Tools | |
Display Modes | |
