Old 07-29-2024, 07:06 AM   #1
jaros44sr
jaros44sr's Avatar
Antenna
Has anyone successfully managed to take an antenna cable apart. Been looking at it for a couple days and can’t find a way to replace cable
Untitled by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 07-29-2024, 07:37 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Antenna
[quote=jaros44sr;9330440]Has anyone successfully managed to take an antenna cable apart. Been looking at it for a couple days and can’t find a way to replace cable
Untitled by [url=https://www.flickr.com/photos/97391199@N06[/quote]
You need to find a local Ham shop. CB would have done, but that's archaic now. Get some fresh coax, and have them put a fresh plug on the end.
Old 07-30-2024, 07:39 AM   #3
jaros44sr
jaros44sr's Avatar
Re: Antenna
Thanks for your time I'll do a search in my area
SAFETY FIRST
AS usual, off topic
Jim
Old 07-30-2024, 08:15 AM   #4
jaros44sr
jaros44sr's Avatar
Re: Antenna
Never saw the insides dremel tool time
SAFETY FIRST
AS usual, off topic
Jim
Old 07-30-2024, 08:47 AM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Antenna
If repairing the original doesn't pan out, this is all available new for around $60.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 07-30-2024, 09:58 AM   #6
cj847
cj847's Avatar
Re: Antenna
I took mine apart and replaced the cable. You need to pull that strap clamp off and the rubber piece will come off. Then you can see what you need to solder.
cj847 is offline   Reply With Quote
Old 07-31-2024, 09:20 AM   #7
jaros44sr
jaros44sr's Avatar
Re: Antenna
Thanks guys for the info and. Help, I thought the strap clamp was the ticket but wasn’t sure
SAFETY FIRST
AS usual, off topic
Jim
Old 07-31-2024, 12:08 PM   #8
jaros44sr
jaros44sr's Avatar
Re: Antenna
https://flic.kr/p/2q7piQ5
SAFETY FIRST
AS usual, off topic
Jim
Old 07-31-2024, 12:47 PM   #9
jaros44sr
jaros44sr's Avatar
Re: Antenna
Picture to large
SAFETY FIRST
AS usual, off topic
Jim
Old 07-31-2024, 08:43 PM   #10
'68OrangeSunshine
Re: Antenna
The thing with all coaxial cable [COAX] is that center wire is the HOT lead, that receives or tramsmits signal. The braided sheath of the outboard cable is the Ground. It should be grounded to the chassis on one end and soldered to the outside metal of the plug.
Old 08-01-2024, 09:35 AM   #11
jaros44sr
jaros44sr's Avatar
Re: Antenna
Thanks for the advice
SAFETY FIRST
AS usual, off topic
Jim
Old 08-01-2024, 09:55 AM   #12
jaros44sr
jaros44sr's Avatar
Re: Antenna
Able to get rubber boot off with minimal damage to clamp, unsure next step
image by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 08-01-2024, 10:00 AM   #13
jaros44sr
jaros44sr's Avatar
Re: Antenna
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2024, 11:21 AM   #14
jaros44sr
jaros44sr's Avatar
Re: Antenna
Found this male plug in box
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2024, 11:30 AM   #15
jaros44sr
jaros44sr's Avatar
Re: Antenna
This maybe an exercise in futility
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2024, 11:38 AM   #16
jaros44sr
jaros44sr's Avatar
Re: Antenna
Nope crises averted just to much glue inhaled while I was building plastic car models
image by [url=https://www.flickr.com/photos/97391199@N06/]James Jaros
SAFETY FIRST
AS usual, off topic
Jim
Old 08-04-2024, 06:31 AM   #17
jaros44sr
jaros44sr's Avatar
Re: Antenna
Cutting off crimp……….destroying part
SAFETY FIRST
AS usual, off topic
Jim
Old 08-04-2024, 09:03 PM   #18
'68OrangeSunshine
Re: Antenna
You should be able to get a fresh male Antenna Plug like that.*
Strip the Coax back. The center wire is the lead or Hot side. Often made of copper. Solder that inside the thin probe. After peeling back the outer insulation, there's a braided core. That's the Ground side. That should be soldered [or crimped] to the outboard of the plug. [Solder's better]
That type plug relies on friction to stay in the radio socket, so bend back the wings on the outside of the plugs for a tighter fit if needed.
*Radio Shack might carry it in their online store. Or Francis Wire Works.
That type isn't really reusable.
Old 08-05-2024, 07:34 AM   #19
jaros44sr
jaros44sr's Avatar
Re: Antenna
Thanks for the reply and information, right now having trouble sourcing parts. Will try Ron Francis when he opens up. Maybe radio shack
SAFETY FIRST
AS usual, off topic
Jim
Old 08-05-2024, 06:11 PM   #20
jaros44sr
jaros44sr's Avatar
Re: Antenna
Was able to pry gasket off. Letting it soak in WD40for a couple days
SAFETY FIRST
AS usual, off topic
Jim
Old 08-09-2024, 10:00 AM   #21
jaros44sr
jaros44sr's Avatar
Re: Antenna
Better
SAFETY FIRST
AS usual, off topic
Jim
Old 08-09-2024, 07:22 PM   #22
'68OrangeSunshine
Re: Antenna
[quote=jaros44sr;9332734]Better
image by [url=https://www.flickr.com/photos/97391199@N06[/quote]
Looks like there's a lot more to the stock antenna base than aftermarket. The inside part of the non-stock antennas just has a metal ''cage'' to brace against the upper mast. There must be some electronic ''guts'' in the one in the pic.
Jim -- Did you get a male radio plug or brand new radio coax lead yet?
Old 08-10-2024, 09:15 AM   #23
jaros44sr
jaros44sr's Avatar
Re: Antenna
After talking with Wayne at Ron Francis, he mentioned Cruthfield, so on Monday I’ll give them a call
No luck so far in finding cable ends, still sourcing parts
There is a plastic piece inside that I would like to clean up, looks kinda tatty, maybe cut half off and slide a sleeve on
It looks like it may be swagged on there, I don’t know
SAFETY FIRST
AS usual, off topic
Jim
Old 08-10-2024, 09:49 AM   #24
jaros44sr
jaros44sr's Avatar
Re: Antenna
I agree does look a lot beefier then reproduction
This end only has the female plug, I’ll flare the tabs out on Dinah assembly
SAFETY FIRST
AS usual, off topic
Jim
Thread Tools
Display Modes
