10-10-2024, 01:00 AM | #1 |
Senior Moment
Any LS Guys out there
I’m running an LS 1 5.7. I have a noise that is coming from my Intake Manifold that sounds like Something Rattling around in my intake. It’s different than a lifter noise plus it comes and goes. I recently put a set of Trick Flow heads and Cam in. Now I’m hearing the Michigan Motor Sports lifters I bought might be the problem. Anybody know anything about this??? I thought did my research but it turns out I could be wrong. Any input would be appreciated
Thank you
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-10-2024, 04:00 PM | #2 |
Re: Any LS Guys out there
I would ask the same question over on LS1tech.com.
On my LS swap projects I use the "real" GM LS7 lifters and lifter trays. |
10-10-2024, 04:14 PM | #3 |
wish I could help, but my LS1 is stock as pulled from a 2002 TransAm.
I did put a set of MM upgraded trunnion rocker arms on it. Other than the usual cold engine piston slap, it's really quiet on the top end.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
10-10-2024, 08:05 PM | #4 |
Senior Moment
I though that’s what I was getting
10-10-2024, 08:07 PM | #5 | |
Senior Moment
Just started this after about 500 miles.
10-11-2024, 07:22 AM | #6 |
Pull the valve covers and make sure a rock arm isn't acting up or loose.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
10-11-2024, 10:15 PM | #7 |
Senior Moment
I’ve looked all the obvious things that it could be, all looks good. Next step is tearing into it.
10-12-2024, 12:09 AM | #8 |
All about them K’s
I own a 5th gen Camaro SS and Michigan motorsports is widely known in the 5th gen world as a vendor to avoid. Most of us 5th gen performance guys use vendors like TSP, GPI(my personal favorite), and Thompson motorsports, just to name a few. MM is known to sell a good bit of Chineseium crap. I wouldn’t run those lifters unless you can verify they are indeed GM parts. The GM LS7 lifters are a good part but the GM caddy racing lifters are even better for overall durability and performance. GM tested and ran them on the C7R and other platforms to 8500 RPMs without issue. Johnson’s are a slight step up from the caddy racing but are significantly more expensive. For trunnions, smith brothers has a good setup as does CHE. Did you do a trunnion upgrade? If not that could be your issue. The OE needle bearings in the rockers are known to fail with the high lift and spring pressures of bigger cams.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
10-12-2024, 01:36 AM | #9 | |
Senior Moment
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 10-14-2024 at 11:28 PM. |
10-12-2024, 10:27 AM | #10 |
All about them K’s
Talk to GPI in Arkansas. All they mess with is LS and LT engines. They now there stuff inside and out. They can help you. Andrew Cammer is a true bad ass at answering questions, and point people in the right direction.
Thread Tools | |
Display Modes | |
