help with 4x4 rotor again
Hey all
I have been trying to get my rotors off of my 71 1/2 ton 4x4. I have the hub off, and the nut behind that off. Then I took the big aluminum piece off. Here is a pic of where I am at. I need to get that washer looking thing with all of the holes out. How?? Blazerman told me to take that out and then there should be another nut behind it, but I can't get the washer off. It doesn't turn or anything - is there a trick or special tool I need? Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
It should have a tab on it and it pulls straight out. Slides in a key slot. May have one of the tabs peened over into a slot in the nut behind.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
The spacer with all of the holes fit over a pin, (same size as the holes) and it prevents the inside nut from coming loose as it is keyed to the spindle. Usually a magnet will pull it if you pull it straight out. Sometimes the grease will keep it stuck and if you wash off the grease it will make it come out easier.
The washer functions like the castellated nut on the two wheel drive spindle so that you can adjust the bearings. Jim |
if you have the snap ring pliers that you used for the axle snap ring that is the easiest way to remove it. it may not have a tab on it to grab, the earlier ones did not have that. there is another nut behind that lock ring that has a pin that you have to line up the lock ring to when you reassemble your project. be careful not to smash it, if this happens the drivers side will loosen up, and the passenger side will tighten and burn up the bearings.
yeah, but how's it wheel? |
I use like two dental picks to get mine off, just hook them on each side of the washer and wiggle it off, like the boys said you'll see a pin on the inside nut that fits in one of the holes in the washer, make sure it goes back together right, if you have doults when your putting it back together don't hesitate to post, better safe than sorry
I got one side off but the washer just won't come off the other side. Not sure what I will do. I don't think the rotors need to be turned so I may end up putting the pads on and calling it good.
I wanted to check the bearings though since I was at it, but I just can't get that one washer off. Any other ideas? Shawn
#7 | |
I would pull it man make sure there is grease in the back bearing. That bearing fails it is dangerious and if it does lock up from lack of grease it'sa real pain to cut the hub assembly off. As for not truning the rottors. glazed rotors and new pads make poor brakes. get them turned. Change the brake fluid and you will be surprised at how well the brakes on these truck can work if you don't cut corners.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
I had one spin a little once. So it got off line with the groove that the tab slides along on the inner diameter. Check to make sure that the tab and groove are aligned. If not, use a long punch/pick to twist it back and then it should slide out as normal.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach (upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL) 71 Custom Deluxe 350/350 Tilt/PS/PB 00 Blazer |
I had a nut and washer assembley turn on me also. I took a punch and tapped it CCW to get the tang back into the slot on the spindle. But the washer ended up boogering up the threads on the spindle. I had to put the spindle nut socket on the 1/2 impact gun and it came off hard the whole way. Then i cleaned up the spindle with a thread file and bought a new nut and washer at the auto parts store....Fixed!!
Randy ![]() ![]()
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Thread Tools | |
Display Modes | |
