Old 02-01-2004, 03:31 PM   #1
griesel72
griesel72's Avatar
Is it possible
Just wondering if it would be possible to swap a 69-72 cab and front clip onto a 76ish frame. I think that i could grind the rivets off of the 69-72 frame and weld them to the newer frame for the cab and front clip to line up, and then use a flatbed so i could get around centering the wheel in the wheelwells.
Would it be an easy swap, or am i setting myself up for a whole lot of work.
Also, will a 69-72 steering column line up with the newer pwr steering box with no modifications.
Thanks for any help
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 02-01-2004, 03:45 PM   #2
smokekiki
Mike
smokekiki's Avatar
Mudder67 has done it for one.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-01-2004, 06:53 PM   #3
Mudder
Mudder's Avatar
I believe I may have used the newer shaft from the steering column. The rag joints were different some years but could probably be made to work. If you have a hoist to hold the cab in place it would be a lot easier to get the cab mounted. The older mounts will be very close to where the newer mounts are now. Just gotta watch out for the distributor clearence. The rest is a piece of cake. A body lift will be very helpful.
Mudder is offline   Reply With Quote
Thread Tools
Display Modes
