Old 02-03-2004, 01:06 AM   #1
robby
Semper Fidelis
robby's Avatar
Question Aluminum 72 Blazer?
Questions:
Can you paint an aluminum intake manifold with Chevy orange paint and have it stick and not come off?
What years are CST Blazers? Is it possible to have a 72 CST? For some reason I am thinking CST was earlier. I just looked at a 72 Blazer that had CST badges on the doors. This thing was loaded with PS, PB, air, posi, trim stuff, etc.
another ?-can I use the 16" 8 lug rims I got off of my 79 on a 8 lug 3/4 ton truck with drum brakes? I heard that the lug size was smaller on the drum set up.
Thanks for the help with the cranial rectumitis.
72 Chevy C 20 with 402 For sale
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
robby is offline   Reply With Quote
Old 02-03-2004, 01:09 AM   #2
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Go to your....
local paint supplier and get a spray can of self-etching primer and prime it with that first and the you can paint it. Later, FCG
FuelCellGuy is offline   Reply With Quote
Old 02-03-2004, 01:14 AM   #3
Randy70C-10
Randy70C-10's Avatar
Self etching primer will work but it goes on kinda thin. You can use urethane primer and wet sand it smooth before you paint.
Randy70C-10 is offline   Reply With Quote
Old 02-03-2004, 01:23 AM   #4
1972C10
1972C10's Avatar
Prime an intake? Ive just painted them with dupli color engine paint and not had any problems
Ive painted some of them stock alum Intakes and some aftermarkets I just make sure there grease and oil free by wiping them down it carb cleaner or laccquuer thinner.
1972C10 is offline   Reply With Quote
Old 02-03-2004, 01:53 AM   #5
1969 GMC
1969 GMC's Avatar
CST was an option on all 69-72 blazers. however, the last year for it on trucks was '70. After that it became the Cheyenne and Cheyenne Super trim.
and yes, you can use the newer rims. i don't know what size they are, but 15" was stock with the drums. only need to worry about size when you upgrade to discs, you will need to grind calipers to fit 15" over the rotor. But 16" and 16.5" will work AOK.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-03-2004, 12:16 PM   #6
68 Suburban
68 Suburban's Avatar
Can urethane primer be used over paint? The reason I ask is, if I sand some surface rust spots, there will be bare metal that meets with the existing paint. Am I going to worry about feather edging with the original paint?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 02-04-2004, 12:19 AM   #7
robby
Semper Fidelis
robby's Avatar
thanks for the input. The rims I have are 16" off of my 79. If I can sell more stuff I may get this Blazer.
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Old 02-04-2004, 12:26 AM   #8
Gee_Emm
I just used regular engine paint on an aluminum intake for my 69. It has held up well but I don't drive the truck all that much. I just did a 6cyl intake with the por15 stuff, worked out ok.
Gee_Emm is offline   Reply With Quote
Old 02-04-2004, 12:33 AM   #9
robby
Semper Fidelis
robby's Avatar
The reason I ask may seem obvious but what I want is to use the edelbrock intake and carb with the motor looking original as possible. I can use my stock air cleaner with a 1406 right?
85 GMC K2500
83 Trans Am
Cedar City, Utah
(Missouri Native)
Thread Tools
Display Modes
