Old 02-03-2004, 05:22 PM   #1
72sub
Master cylinder question
Anybody know what the type and size is of the master cylinder/brake line fittings ('72 1/2 ton w/power brakes)? I'm trying to round up/make some adaptors for bench bleeding. Thanks.
72sub is offline   Reply With Quote
Old 02-03-2004, 08:53 PM   #2
rage'nrat638
rage'nrat638's Avatar
MAN THAT SOUNDS LIKE TO MUCH TROUBLE.....
go to napa and buy a master cly. bleeding kit.....
cost about 6.00....
then you can bleed any standard thread master cyl....
spend 12.00 and get the metric and standard set's now you can bleed any car or truck
just a thought.....
the two fitting are different from the front to rear on a stock master,,,,hope this help's
rage'nrat638 is offline   Reply With Quote
Old 02-03-2004, 09:19 PM   #3
72sub
ok, thanks. i haven't seen the cheap bleeding kits, but i'll look again. i think i want one of those 638 c.i. big blocks also.
Old 02-03-2004, 09:22 PM   #4
rage'nrat638
yea the fittings are plastic multi-fit thingys....with little rubber hose's that slip right on them....i think the standard size is blue and the metric is red...or the other way around
Old 02-03-2004, 10:59 PM   #5
roadking
you can find them in the HELP section of most autoparts stores
roadking is offline   Reply With Quote
Thread Tools
Display Modes
