Old 02-03-2004, 05:22 PM   #1
03glide
Sell it before it's finished
03glide's Avatar
Which motor mouns?
The motor mounts in the '68 swb I just picked up don't look like the ones in the 283 truck. How can I determine what engine was in this truck by looking at the mount?(small/big block, inline 6). I will try to post some pics tomorrow.
03glide is offline   Reply With Quote
Old 02-03-2004, 05:27 PM   #2
smitty62
smitty62's Avatar
Maybe by looking at which holes are being used for the mounts. Believe the frontmost holes were for a V8. Is that frame for your use or to sell?
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-03-2004, 05:29 PM   #3
03glide
03glide's Avatar
I am going to sell it as soon as I get some parts off.
Old 02-03-2004, 05:35 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Try the VIN stamped on the framerail by the steering box. If CS, then I6, if CE, then it was a V8. Same with glovebox model # or Vin tag on cab.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 02-03-2004, 06:10 PM   #5
03glide
03glide's Avatar
Thanks, I'll look when I get home. Are small block and big block mounts the same. If not, how can I tell the difference?
Old 02-03-2004, 06:17 PM   #6
smitty62
smitty62's Avatar
Same holes-not sure about the mounts themselves.
Smitty
Old 02-03-2004, 06:53 PM   #7
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
The 6 cylinder mounts are longer and bolt in the back holes. the v-8 mounts bolt up front. A v-8 will mount on the 6 cylinder stands but it must be in the 6 cylinder position which means no room behind the distributor and then you have a drive shaft and tranny linkage issue.
Suicide-D is offline   Reply With Quote
Old 02-03-2004, 09:13 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Big block mount's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-03-2004, 10:09 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Here's the pic or not it won't let me resize it if anyone need's a pic pm me with your e-mail and I can send it to ya,I think??
MEMBER #6377
Project "7DEUCE"
Old 02-04-2004, 12:59 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget the CM VIN on the GMC trucks with the V-6.
Thread Tools
Display Modes
