Old 02-12-2004, 06:12 PM   #1
Mountain Man
question for GMC owners - front grille
I see that you can now get a repo 67 chrome grill.
I want to know how difficult it is to change out a GMC 67-72 grill.
I assume that you pull the bumper, and headlight bezels, and then there are screws that hold the grille on. Can someone tell me if this is accurate. I want to know how difficult the job is before I consider doing it. I can't see my truck right now because I am travelling away from home.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 02-12-2004, 06:41 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Just replcaed my core support and re-painted my grill (PO had previously painted it). Any way, I did not remove my bumper. Remove front parking lights. remove headlight trim. Un bolt grill from hood latch. should also be a bolt at bottom. 67-68 have a piece that connects between bottom of support and grill remove this(runs width of vehicle). should be 8 bolts (4 per side) connecting grill to fenders. should be able to lift out.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-12-2004, 07:20 PM   #3
J.Lance
Too many is never enough!
grill
I find it easier to take off the front bumper especially if you're putting a nice grill back in. I also loosen (not remove) the bolts going from the radiator support to the fenders in order to spread the fenders a little and make it easier for the grill to slide out from between them. 4 bolts per side as mentioned between the grill and fenders, 2 on the top and 2 on the bottom. I found it easier to leave the center grill support on the grill and unblot it from the radiator support but that's just me. Headlight bezels do not need to be removed as they will stay with the grill when removed but you do have to either take out or unplug the running lights in the grill. As mentioned, must also remove the air dam on '67 and 68. Pretty simple, should have it out in about 15 min. or so. Good luck.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
Old 02-12-2004, 11:08 PM   #4
Blue Beard
Blue Beard's Avatar
Have to agree with lance, fairly easy task to handle...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-14-2004, 11:42 PM   #5
Mountain Man
Well thanks for the tips guys.
Went out to the garage today at 2pm, and returned at 4:30pm. A bit longer than a 15 minute job, and one broken bolt, and out it came. The 37 year old bolts were very seized and man are they hard to get at thru the grill, but I got it out without damage.
I sure hope the new repro. 67 GMC grille goes in o.k. and fits reasonably well. I have been waiting for over 3 years for their availability. I will be receiving my new grille within 2 weeks from the U.S.
Full trim
Factory tach dash
A/C dash
Factory tilt
Old 02-15-2004, 09:33 AM   #6
Tim Christian
Tim Christian's Avatar
Check out the new grill good every 67 I have received from them has splits. It looks like they did not allow enough metal to stamp the GMC in it. I was not happy with overall quality of them and now I do make sure the customer is aware of this before they buy it. I found this out on the first one I sold but did offer a full refund. Thanks Tim
Tim Christian is offline   Reply With Quote
Thread Tools
Display Modes
