Old 02-13-2004, 01:15 AM   #1
1971 2wd
38" tall tires
Hey all, just wondering what size lift people are using on there 67-72 Blazer's/Truck, that will fit 38" tall tire's??
If you are able to post pics, please do..
Thanks!!!!
72 blazer, 71 2wd short bed, 67 nova
Too many damn toys!!
1971 2wd is offline   Reply With Quote
Old 02-13-2004, 06:20 AM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
with out a lift you can squeeze 33X12.5, and with 3-4 you can get 35s. So I am guessing you need at least 6. Sorry don't have much expirence with the 38s
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 02-13-2004, 08:09 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's some 38's on my none lifted 71.
well obviously this can't be done without at least 4-6" of lift.
I was at a buddys place and we had his 38's off his truck.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-13-2004, 10:59 AM   #4
smokekiki
Mike
smokekiki's Avatar
2WDBlazer from florida is running 38's with 9" of lift.He has a pic of his blazer in his avatar.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-13-2004, 11:16 AM   #5
Bluegoose972
A rule of thumb that I use is 1" of lift for every inch of tire over 30". Therefore, a 35" tire will typically require 5" of lift. Most people are running 6" lift, but a few are running 4" with some rubbing. A 38" tire should require 8" of lift. For our short wheelbases, I'd use a 6" suspension and 3" body, for 9" of total lift. Just my $0.02.
Rick
Bluegoose972 is offline   Reply With Quote
Old 02-13-2004, 01:10 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'd say that Bluegoose's rule is about right. I'm running 35's with a 6" lift. My first K5 had 35's with a 4" lift - never got it offroad so I don't know if it rubbed. I'd say minimum of 8" for 38's. Even with that, you may have to trim the front fenders a little. The wheel width and offset have a lot to do with it too. If your running 12" wide wheels with very little rear offset, your tires are probably going to rub when you turn/flex.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-13-2004, 02:38 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have 9 inches and true 38's. The PJ's are actually 38.2. I would say a minimum of 8 if you are doing it just for looks. Mine rubs under medium wheeling. I would recommend an 11 inch lift. 8 inch spring and 3 inch body if you want to wheel around decently. There are some pics around if you search. I don't have them handy.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-13-2004, 02:49 PM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Here ya go http://67-72chevytrucks.com/vboard/s...threadid=72587
and
http://67-72chevytrucks.com/vboard/s...threadid=69058
Old 02-14-2004, 01:29 AM   #9
LeRoy
Registered truck nut
LeRoy's Avatar
I agree with you all. The biggest problem I had with 7" and 36x14.5x16.5 swampers was hitting the front of the rear wheel well. This was after flexing it pretty good. Some zero rates would probably solve this. Right now, I'm trying to find the time to finish the new lift on it. For the front I have some 6" Skyjacker springs and for the rear an ad-a-leaf, zero rate and a shackle reversal. The tires are 38x15.50x16 Swamper SSR's. I've done the front and have tons of room and should have plenty in the rear. After trying the new tires with the old lift I would have been fine with just the zero-rate recentering the rear wheel. Dang, should have bought 40inchers, lol
MOUNT VERNON, WASH. STATE
Need a part? Just PM me
LeRoy is offline   Reply With Quote
Old 02-15-2004, 10:44 PM   #10
1971 2wd
Leroy, so you are saying 38" swampers will work with a 6" superlift??
If so that make me a happy camper!!
Thanks for all the reply's!!
If you have any more please throw them at me..
Thank you
Old 02-16-2004, 01:04 AM   #11
LeRoy
LeRoy's Avatar
I tried them with 7 inches of lift but didn't flex them. I think with the rearend centered the only trouble you might run into is the front fender bucket. This all depends on how much actually lift you gain and what you plan on doing. It's kind of a crap shoot with lift and tires ect.
Old 02-16-2004, 01:11 AM   #12
1972C10
1972C10's Avatar
Here is a pic of a friend of mines truck these are 38.5
1972C10 is offline   Reply With Quote
Old 02-16-2004, 11:43 AM   #13
1971 2wd
My plans are a 6" skyjacker or superlift, springs In the rear (no blocks)..
38x15.5x15 superswampers with a 6/4 back spacing. (all ready have them)
Also rear 4" shackle flip. (Home made Jobber)
Droping the front leaf spring mounts down 4". (That will give a 4" lift). So that will give me a total of 10" lift
It seems a 6" lift will work for street driving, but it will rub when it flexs.
Thanks agian for the replys!!
I'am taking a ditigal pics of everything, once I'm done I will have a Blue print so other's would like to see..
Old 02-16-2004, 02:52 PM   #14
desertchevy
lift
I just ordered the skyjacker 8" system for my suburban. I will be running 37x12.50x17 SSR's on it. Should clear no problem. Of course they probably don't actually measure up to 37" though.
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
Old 02-17-2004, 04:45 PM   #15
1971 2wd
Hi all, well I bit the bullet today. I just order a 8" lift (leaf spring front & rear) for my 72 Blazer.. I can't wait to get it installed (hopefully this weekend)..
When I'am done I will post some step by step photo's!!
Thanks for all the reply's and helping me to make the decision..
Old 03-28-2004, 04:38 AM   #16
1971 2wd
Well I figure out how to post pics. So heres before..
Old 03-28-2004, 04:41 AM   #17
1971 2wd
And here is after..
8" Skyjacker lift / 7000 nitro shocks
38" Super Swampers
15x10 Rock crawler rims with 6/4 back spacing
Steel braided brake lines
Old 03-28-2004, 04:46 AM   #18
1971 2wd
Here it is parked behind a 2003 Honda Accord.
Old 03-28-2004, 04:01 PM   #19
bouncytruck
SKINNY TIRES RULE!
Very nice. How does it ride? Do you have much bump steer?
bouncytruck 1972 K5
Old 03-28-2004, 07:45 PM   #20
1971 2wd
Surprisingly, really good. It has a little bit of bump steer, plans down the road is to do a cross-over steering.
Old 03-29-2004, 03:55 PM   #21
Yukon Jack
Post Whore
Yukon Jack's Avatar
What brand did you end up going with?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-29-2004, 05:32 PM   #22
Big J
Its lookin' like a Blazer!
Big J's Avatar
I know its not a sports car, but how does it handle? Does it feel like its going to roll while going around a curve at 55-60?
Big J is offline   Reply With Quote
Old 03-29-2004, 07:02 PM   #23
Bluegoose972
Oh GREAT.....You just had to go and show that picture!! NOW I WANT 38" TIRES! Now you just need to run over that Honda!
How is your driveshaft angle? Are you getting any vibration at highway speeds? How about under power....any clanging?
Old 03-29-2004, 07:20 PM   #24
BIG_BLAZER86
BIG_BLAZER86's Avatar
Whats the height from the bottom of your bumper to the ground, I wouldn't mind putting a 8" on my 69, but it might be to tall for the lift law here in ohio.
81 blazer 2wd tukin 30's
07 Jeep Grand Cherokee on 26's
Tube chassis 5.3,dual T cases,54" boggers,steering rocks
Dodge 3500 with some mods
BIG_BLAZER86 is offline   Reply With Quote
Old 03-29-2004, 10:40 PM   #25
1971 2wd
Yukon Jack - Skyjacker soft ride ( full springs )
Big J - Yeah it feels a little top heavy but, it's something I have to get used to.
Bluegoose972- The springs came with degree shims built in, the only vibration that I'm feeling is from the tires. Yes it is underpowered, but ok for a wore out 350. No clanging so far!
BIG_BLAZER86- Measured from lowest part of bumper it's sitting about 31 inches.
Thread Tools
Display Modes
