Old 02-14-2004, 02:40 PM   #1
Dusti
Not Dusti,just Bob
Dusti's Avatar
Post air filter for 6 cyl ?
I finally got the disc brake change over done on my 3/4 ton ,now that I have a power brake booster the old stock air cleaner wont fit,the truck has a 292 6 cyl.I know there are factory air cleaner assemblys for trucks with power steering but I dont think I will find one and if I did it would be expensive.
The only air cleaners I have seen in the parts stores that would work were very small,about 4" across,I would like something bigger.
I will check the K&N website to see if they offer any custom air cleaners for 1barrel carbs.
anybody got any pics of what they are using???
Bob
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
Old 02-14-2004, 03:16 PM   #2
If you can find it, they make a stock filter assembly that extends the air filter over to the passenger side of the block to clear the booster. Off the top of my head that is the only one I can think of short of those itty bitty aftermarket ones.
Old 02-14-2004, 03:25 PM   #3
Canada20
one of those old Moon style ones might do the trick?
Greg
No such thing as a stupid question, right?
Canada20 is offline   Reply With Quote
Old 02-14-2004, 03:32 PM   #4
1969 GMC
1969 GMC's Avatar
the brake booster 6 cyl air cleaners aren't that expensive, but they are hard to find. i found one a few weeks back for $30 on eBay, and I don't believe anyone bid on it. I would check there.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-14-2004, 05:46 PM   #5
Gee_Emm
These are in the same price range as ps brackets.
Gee_Emm is offline   Reply With Quote
Old 02-14-2004, 08:10 PM   #6
Warrens69GMC
Warrens69GMC's Avatar
I'm using-
What I am going to use is an offset base K&N filter ('round $60) oblong air cleaner. Find it in the back of K&N catalog.
might need an adapter.
warrens69gmc
Old 02-14-2004, 08:40 PM   #7
smitty62
smitty62's Avatar
Do you want a GM or aftermarket? I've got an original off a '68 250 that I think would work, but it won't be like yours or Gee-emm's
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-14-2004, 11:20 PM   #8
PR454SS
PR454SS's Avatar
What if you use a spacer like is on this carb, it's about 2 in high
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Thread Tools
Display Modes
