Old 02-22-2004, 02:12 AM   #1
Chevyman90
Power steering problems
I recently bought someones project truck, a 1978 silverado shortbed converted to a 3/4 ton 4x4 the problem I am havin is to do w/ the power steering previous owner cut the lines so i had to put new hoses on the steel lines, and everytime I tightin down the hose clamps and test it out if i turn it full bore to one side the hose shoots off and fluid goes everywhere, is there a way to prevent this from happenin or will i have to get stock lines w the special fittings , I have yet to flare out the steel lines since ive been in a hurry do you think if i flare them out it will be less likely to shoot off the line?
1990 cheyenne 1500
Chevyman90 is offline   Reply With Quote
Old 02-22-2004, 10:59 AM   #2
76bonanza
76bonanza's Avatar
The pressure line will have to be the one made with the fittings in it no clamp will hold it.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Thread Tools
Display Modes
