Ultimate Diesel Dude
I finished the dash lights upgrade tonight. Wow! What a difference! My lights are at least twice as bright, if not brighter, than before! I also painted the needles as was suggested. This is a really good, low-budget mod. It's probably one of the best 'bang for your buck' mods you can do! I plan to do Mike's dash upgrade one day, but this is definitely a huge improvement over the way it was!
One of my turn signal indicator lights was burned out, so I decided this was a good time to do this upgrade, since I had to tear into the dash just to get to the darn bulb. I discovered that one of the circuits for the dash lights on the printed circuit board was nearly melted, so I did some 'hillbilly' wiring and bypassed some of the circuits with actual wiring. I installed the 168 bulbs too. I was also able to fix the pesky high-beam indicator, since it only wanted to work once in a while. I sure appreciate this board and the members on it for this suggestion! Casey
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's |
Mudslides 'r my specialty
How long did it take to do this mod? Can I do it after work, or should I wait for the weekend?
What did you paint the needles with?
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
Professional Grade
8t5Silverado -- The part that took the longest was waiting for the paint to dry
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
85,
I think my total project time was around 2.5 hours, including repair the circuit board. I didn't know it, but I had also purchased 'fast-drying' paint. I used chrome spray paint I found in the auto section of Wal-Mart, and bright 'glowing' orange spray paint from the paint section of the same store. Both paints dried to the touch within minutes. Very cool! If all goes as planned, you could do it after work one night. However, if you've never been into the dash before, and if something breaks in the process, you might want to allow more time. I would probably wait for the weekend if I were you. I started on mine last night, and finished it tonight. But I didn't have to drive the truck today, either. Casey
like i said before if all you are doing it painting the plastic blue reflective panel chrome, and NOT pulling the entire cluster, it wont take very long.
i still have another bright dash light upgrade i want to try. i have done this one and it helped....i also run the 168 bulbs, but have something else in mind i want to try.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Jon,
What you got in mind, you sparked my curiosity?!?!? ![]()
1987 Chevrolet Silverado 2005 Chevrolet Silverado |
Wow, I should have taken a patent out on this one - - I could retire on the royalties
![]() ![]() ![]() Casey, I'm glad to hear it worked for you as well. I'm looking forward to getting back to work on my truck as well. I want to upgrade the bulbs and do the gauge needle painting too. Let's keep helpin' eachother... ![]() ![]() ![]() |
you will see when i do it, dont want someone else taking credit...
#9 | |
Re: I did the 'brighter dash lights' upgrade too!
Who is this Arveetek guy?? Is he a new guy? ![]() ![]() Casey! Whats going on man? I havent seen you like in ages. Hey man, you wouldnt happen to have an extra 6.2 laying around would ya? Mine died. ![]()
Steve 86 K30 4x4 6.2L Diesel\TH400\NP208 - 14bolt FF rear w/detroit locker and Dana60 front w/detroit locker- both with 4.56 gears "Runs on Mud" |
Happy to be here
![]() Join Date: Mar 2000
Hey I just did the dash upgrade too. Well actually I cheated and had it done. Crossy happened to have the parts I needed to repair my tach dash. I shipped it to him, and he changed the odometer that was all dingy, and the gas gauge that the PO had "tried" to paint over the Unleaded Fuel Only script.
Here's the results... Before
Happy to be here
After...
yeller
Looks good Ken!
Dave, you did a good job. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#13 |
Looks like Crossy put fuel in your tank too by looking at the fuel gauge.
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
#14 | |
Re: Re: I did the 'brighter dash lights' upgrade too!
Hey Steve! I still lurk around here from time to time! I read a lot of the posts, I just don't post much myself. What happened to your engine? Yeah, I got a spare 6.2L sitting in the garage, but it needs rebuilt. It's my parts engine! I got a whole corner full of 6.2L junk. Casey
#15 | |
Re: Re: Re: I did the 'brighter dash lights' upgrade too!
Well just before christmas, the tranny went out, got it rebuilt and a month later the motor started knocking. So I just parked the damn thing. Any ideas?? ![]()
#16 | |
Re: Re: Re: Re: I did the 'brighter dash lights' upgrade too!
you know that's not good for it, right? ![]() |
#17 | |
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
#18 | |
Well, sometimes an injector can go bad and cause a knock. What you can do is start it up, and then loosen one injection line at a time. If the knock goes away when you loosen a line, then that injector/cylinder is the problem. You can then swap injectors with one on the other side of the engine. If the knock moves to the other cylinder, then it's the injector for sure. If the noise stays in the same place, it's something internal in the engine. Is it a realy loud knock? Casey
#19 | |
Happy to be here
#20 | |
Insert Witty Text Here
![]() Slonaker |
#21 | |
Re: Re: Re: Re: Re: I did the 'brighter dash lights' upgrade too!
It does seem louder in the mornings when cold and when going down the highway. I think I am going to save for a 6.5L turbo.
![]() ![]() Quote:
Thread Tools | |
Display Modes | |
