03-02-2004, 07:24 PM | #1 |
LED King
Trany Splines - need answer fast
Does my stock 85 TH700 come with a 27 or larger spline?
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
03-02-2004, 08:23 PM | #2 |
LED King
ttt
03-02-2004, 10:09 PM | #3 |
I'm 90% sure it's a 27, I don't think they used the 30 spline until 87...
03-02-2004, 10:21 PM | #4 |
You get what you pay for
There are basically 3 versions of the 700r4. From '82 until '84 there was a small-input-shaft unit with the same spline as the 200c transmission. From '85 to '87 there was a large input shaft version, which has the same spline as a 350 trans. The early torque converter ('82-'84) will not install, so there is no danger of using the early torque converter on the large shaft. From '87 1/2 up, the large shaft is still used, but GM incorporated an auxilary valve body to cushion engagement into drive.
Mike 1985 Chevy C-10 |
03-02-2004, 10:34 PM | #5 |
5 day ban, learn to behave.
Ummm are you talking about input shaft or output shaft? I would assume output shaft. 700r4, like its brother the th350, are 27 spline
mike |
03-03-2004, 12:23 AM | #6 |
BAD BOW-Silverado XST
82-84 27 spline
85+ 30 spline One reason I had a 85 Camaro 700R4 core rebuilt for my truck. |
03-03-2004, 02:53 AM | #7 |
LED King
I thought it was 30 but I wanted to make sure. Bowtie Overdrives TH700 is now ORDERED!!! They use an 88-93 core but do have a 27 spline version. Score! I'm EXCITED!
03-03-2004, 07:11 AM | #8 |
Why would they go back to a 27 spline? Unless its hardened. GM went to a 30 spline because stouts engines would strip the input shaft.
03-03-2004, 02:55 PM | #9 |
LED King
For pwople who needed it??? I dunnno.
Thread Tools | |
Display Modes | |
