Old 03-03-2004, 11:53 PM   #1
ocbaud
Garage Queen Material
best way to put hood back on?
i need to put the hood back on the truck. whats the best way to do it, perferablly with only one person(me)
ocbaud is offline   Reply With Quote
Old 03-03-2004, 11:57 PM   #2
Tom
driving is in my blood
Tom's Avatar
carefully
Old 03-04-2004, 12:10 AM   #3
bigblock73
yeller
bigblock73's Avatar
You could use your cherry picker and hold it up with ropes on all four sides while you bolt it down.
Just a thought.
It is pretty easy on a 73-80 (rest the back of the hood on the cowl/hinges while you loosly bolt it on), not sure on a 81+...never done it before.
bigblock73 is offline   Reply With Quote
Old 03-04-2004, 12:36 AM   #4
Destructo
If you care about your paint I would get a couple people to help you out. I pulled mine off when I was taking the cowl off to track down a leak and I don't think I could of ever get it on by myself. But you may be able to rig something up with the shop hoist.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 03-04-2004, 12:37 AM   #5
Deltaskier
I did it once on crutches with a full leg cast by myself on a truck with 4" lift & 35" tires. It sucks. Once I got it up in place, I put a couple of the heavy moving blankets at the rear in an attempt to weigh down the back of it. On crutches, it was extremely hard, but without crutches it would only be somewhat difficult.
Just put something that won't break the windshield at the back of it so that when you lift it in place, it will sort of stay there without you getting a hernia holding it up.
I should mention though, there is no way to do it this way without scratching the paint. Mine was a junk truck that I wahted to get back together so it could be hauled away. After thinking about what I read, I decided you needed that information.
Get a friend to help.
Deltaskier is offline   Reply With Quote
Old 03-04-2004, 01:14 AM   #6
low 84
low 84's Avatar
do you have any friends? get a couple of them over there to help you. lol. trying to put it on by yourself would be more trouble than its worth
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-04-2004, 01:20 AM   #7
Russell
Professional Grade
Russell's Avatar
hehehe, funny.
Sounds like a good plan though
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-04-2004, 12:11 PM   #8
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
DONT do it yourself. You will just tear up your paint and your back
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-04-2004, 12:20 PM   #9
bigblock73
yeller
bigblock73's Avatar
Have your GF help out...she looks strong...maybe even stronger than you.
j/k man
Old 03-04-2004, 12:40 PM   #10
LOHRTBT
LOHRTBT's Avatar
hahaha!!owned!
~Dave~
Old 03-04-2004, 12:57 PM   #11
bpmcgee
bpmcgee's Avatar
You all should be ashamed for giving him such frivolous advice!
The part with the hinge holes goes in back OC.
Brian
bpmcgee is offline   Reply With Quote
Old 03-04-2004, 01:03 PM   #12
LOHRTBT
LOHRTBT's Avatar
I also recommend that you use bolts....they seem to help hold it down hehe
~Dave~
Old 03-04-2004, 02:25 PM   #13
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Yeah, and the shiny side goes up...
Find somebody to help you. It's not worth the risk.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-04-2004, 02:30 PM   #14
lukecp
Formerly yellow72custom
lukecp's Avatar
I agree, get someone to help you. It isn't very hard, dosent' take alot of strength, but it difficult to do alone unless you want to scratch up your paint. Only takes a few seconds to get it on and off with a helper, and they can hold the hood while you bolt it down.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 03-04-2004, 02:47 PM   #15
ocbaud
okay, well the girlfriend said she would help. whats the best way to bolt it down and make sure its lined up good?
Old 03-04-2004, 02:50 PM   #16
bigblock73
yeller
bigblock73's Avatar
Bolt it down semi-tight and close the hood SLOWLY. If it looks like it will hit or is out of alignment...simply adjust it and try again.
You should have traced the hinge outline on the underside hood before you removed it.
Old 03-04-2004, 03:13 PM   #17
Prerunner1982
Prerunner1982's Avatar
yeah we should have dont alot of things.........
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-04-2004, 07:59 PM   #18
ocbaud
yeah, i had to buy new bolts for the hood, cause i lost the old ones
Old 03-04-2004, 08:08 PM   #19
8t5Silverado
You should've marked the location of the hinges on the inside of the hood, that way it goes back exactly where it was.
Old 03-04-2004, 10:08 PM   #20
bigblock73
yeller
bigblock73's Avatar
is there a echo in here...here.....here.........here.......
Old 03-06-2004, 06:53 AM   #21
Nvbowtie
Nvbowtie's Avatar
Oh thank god I did
I lightly etched it with a chisel in case the mark was wiped away.
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 03-06-2004, 01:11 PM   #22
ocbaud
we didnt mark it, because the paint was fadded where the hinges were. its all on and fits great now
Thread Tools
Display Modes
