Old 03-05-2004, 02:17 AM   #1
ocbaud
Garage Queen Material
help a brotha out!
all i got left to get is:
carb
headers
elec. fans
alternator
i'm SO close!
of course i could reuse my headers i had, but i would rather get the new shortie ones now.
ocbaud is offline   Reply With Quote
Old 03-05-2004, 02:34 AM   #2
apstguy
LED King
apstguy's Avatar
I've heard good about Doug Thorlys headers. You want shorties? Why?
Carb - Q-Jet! Edlebrock???
Electric fans - Spal - what company makes a bolt on 2 fan+shroud setup for our trucks (I know it was mega expensive)?
Alternator - Powermaster 140amp one wire
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-05-2004, 02:36 AM   #3
ocbaud
carb- ??? dont know yet :/
fans: hayden 14" dual fans
alternator:??? possibly jegs 100amp 1 wire???
headers: hedman elite shortie headers
i want shorties because my trucks old headers came down way to low
Old 03-05-2004, 02:38 AM   #4
Russell
Professional Grade
Russell's Avatar
I would go with longtube Nova headers myself, don't loose any flow, and they tuck up in the frame rails really nice
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-05-2004, 02:43 AM   #5
ocbaud
Chevy 1967-81 Camaro, 1968-79 Nova, 1964-87 Chevelle/El Camino, 1971-91 Chevy Full-Size, 1970-77 Monte Carlo w/o A.I.R.
500-68608
those are the ones i'm getting. unlike the dynomax shorties, the hedman ones have 1 5/8th tubes and the dynomax have 1 1/2
Old 03-05-2004, 02:44 AM   #6
1FaastC10
1FaastC10's Avatar
Edelbrock 1904 for the carb, dont mess with an Eddy square bore if you want to make power. look for headers with at least 1 5/8" primaries, i dont see a real need for 1 3/4 primaries, but if you wanted to go that route, Heddman Hussler headers for a 67-69 Camaro will fit with slight mods and a custom trans crossmember (i have measurements for a custom crossmember if you'd like i can scan them and send them your way)
1FaastC10 is offline   Reply With Quote
Old 03-05-2004, 02:47 AM   #7
ocbaud
the only thing i'm pretty much undecided on is the carb, and i'm leaning towards a holley 750 vac.
Old 03-05-2004, 03:45 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
With that setup I think a stage 2-3 Jet Q-jet would be better over the edelbrock.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-05-2004, 03:49 AM   #9
1FaastC10
1FaastC10's Avatar
Holleys suck! QJet all the way! nothing like getting power AND milage from the same carb.
Old 03-05-2004, 04:09 AM   #10
TIMSPEED
TIMSPEED's Avatar
Thorley Tri-Y's make CRAZY power!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-05-2004, 10:31 AM   #11
gldevall
gldevall's Avatar
Just bolt all of your old stuff back on to get it in there and get it fired up and running. Then start buying allof the stuff you want. That's what I did. Go the cheap route to get it running and then buy a little here and a little there.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 03-05-2004, 08:47 PM   #12
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Get a Edelbrock 1406 and Smile Q-jets are hard to tune and Holley's won't keep a tune.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-05-2004, 11:45 PM   #13
swervin ervin
You get what you pay for
swervin ervin's Avatar
Q-jets are not hard to tune. Why can't I convince you guys of this.
Jet sells Q-jets with all the tuning already done. They have different stages according to your cam/engine combo. A simple bolt and go. About all they are left to do is adjust the IM screws. Cheaper than the 1904's. This is the way for a carb novice to go. I wouldn't swap my tuned by me 1904 for 5 1406's. Nothing better than the economy or power of a well tuned Q-jet.
As for a Holley. Bah hum bug. It's made for the strip. Not a street carb at all IMO. Sure, easy to make adjustments to them, but come on folks. Them things love gas too much for me. If I've said it once, I've said it a thousand times. No, and I repeat, no carb will give you the the combination of fuel economy and power like a well tuned Q-jet. They have received a bad rep from people not in the know. You guys keep buying them square bore carbs. I'll stick with a tried and true carb.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-05-2004, 11:50 PM   #14
1FaastC10
1FaastC10's Avatar
mike, what about a thermoquad? its essentially the same carb isnt it?
Old 03-06-2004, 12:09 AM   #15
swervin ervin
Junk. Bigger cfm and all, but it's got a plastic throttle body. They will make some massive power, but don't last very long before they are totally worn out.
Old 03-06-2004, 12:16 AM   #16
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
I dunno about that. I've re-worked several Carter Thermoquads over the years (used to be a Dodge man) and they also have an undeserved bad rep. The only real flaw, as was mentioned, is the phenolic resin center section. Sometimes they will warp due to heat. My sollution has always been to use a heat shield designed for quadrajets. I have had many "junk" thermoquads taken to me (by ham-handed shade tree mechanics) and have yet to build one that wouldn't smoke the a$$ of ANY quadrajet. It's like Mike with his Q-jets....you just have to know their flaws, know how to defeat those flaws and know how to tune them. They are VERY finicky, but once tuned, usually stay spot-on. I would put one on my up-coming 454 build, but it is getting harder and harder to get a rebuild candidate that hasn't been molested beyond saving by some twit. I don't really have the time for the finicky tuning procedure anymore, either.
*EDIT* In fact, I spotted an NOS thermoquad on e-ghay, set up with electric choke and chevy linkage (the Thermoquad "performance" model). I bid HIGH on that sucker to mount on my new 454, but i'll be damned if I didn't get sniped in the last 5 seconds. I guess someone else wanted it more than I did.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 03-06-2004, 12:42 AM   #17
ocbaud
gas milage isnt a huge concern of mine.
i'm thinking of possibly getting a newer truck as a daily driver after graduation
Old 03-06-2004, 01:02 AM   #18
phantom dually
Project92 SWB stepside
phantom dually's Avatar
If your wanting all the power you can get from this motor I would scrap the Edelbrock carb idea. Great for a driver but not performance in my opinion.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 03-06-2004, 03:10 AM   #19
low 84
low 84's Avatar
i would put 5 stromberg carbs on it and strap a box fan to the radiator with zip ties.
i figure since you have already got people telling you to do 10 different things i might as well make up another idea.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-06-2004, 03:13 AM   #20
swervin ervin
We're not telling what to do. We're telling him what we would do or have done. Besides, he can't seem to make up his own mind anyway.
Kids. What in the world are you going to do with them?
Old 03-06-2004, 03:20 AM   #21
ocbaud
its only hard to decide on the darn carb.
Old 03-06-2004, 03:45 AM   #22
low 84
low 84's Avatar
people can go on as much as they want about this carb does this and that one does that. but you really AREN'T going to get the best performance out of ANY carb that you buy unless you learn how to tinker with it. so i say buy what ever carb you want and familiarize (sp?) yourself with it. do some reading and some testing and you will be able to figure it out
'05 1500 Crew Cab
RIP
Old 03-06-2004, 12:22 PM   #23
76HighSierra
Marc Bona
Hobbs, New Mexico
3.40 rear.
Old 03-06-2004, 01:20 PM   #24
79BIG10
79BIG10's Avatar
Great advice Ryan!!
Thread Tools
Display Modes
