Old 03-05-2004, 02:28 PM   #1
RockHQ
ROCKET POWER!
RockHQ's Avatar
Ground clearance/drop question
Okay here's the deal. Our government mandates a minimum of 8 CM, or 3.15 inches of ground clearance for all vehicles, this measurement is taken from the lowest point of a vehicle's chassis, or any integral part of the vehicle underbody.
Now since i'll be lowering my 79 C-10, i'd need to know just how low i really can go and still be street legal.
I'd really appreciate if someone with a 3/5 or 4/6 drop (or more)could measure the distance between ground and the lowest part of the frame/suspension, whatever is the lowest point?
Right now i'm thinking of running 15x8 wheels with 255/60/15 front & 275/60/15 rear. Hopefully i can get away with a 4/6 drop, but if not something else will have to do.
Thanks,
-Axle
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 03-05-2004, 02:34 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
4/6 should be fine. In fact 5/7 should be ok also. I know I can get a floor jack under my 4.5/6 drop and it is over 5" tall. The lowest points of our trucks is not the crossmember, it is the lower control arm mounting points.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-05-2004, 02:58 PM   #3
RockHQ
ROCKET POWER!
RockHQ's Avatar
Well that didn't take long
Thanks Chris!
To continue this subject a bit further, If i were to install air bags, what would be a preferable setup assuming i would want to have around 4" of clearance with the bags deflated? I will be installing a parallel 4-link kit, possibly drop spindles, just have to know what my options are.
Old 03-05-2004, 06:00 PM   #4
Captkaos
Captkaos's Avatar
Well, you would probably want to skip the drop components in the front. This is a pic of my bag setup without spindles with the bags deflated.
http://www.captkaoscustoms.com/image...-matchbox1.jpg
This is running 235/70/15 tires. So, in the front you would want to have a taller bottom cup than I do, as in about 3" taller.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-05-2004, 08:34 PM   #5
low 84
low 84's Avatar
with a 5/7 drop and 255/60/15's i have right about 3 inches of ground clearence under my lower control arms. so you should be fine going with a 4/6.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Thread Tools
Display Modes
