Old 03-10-2004, 07:08 PM   #1
cochino12
It followed me home?
cochino12's Avatar
wheel selection sux!!
I am trying to find some rims for the k5 and nobody makes wheels for a locking hub. Anyone have some ideas? I am trying to stay away from this style
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-10-2004, 08:07 PM   #2
Coma
I wanted to put 1 of these style wheels on the Jimmy when i had it. Their all American Racing wheels.
Coma is offline   Reply With Quote
Old 03-10-2004, 09:25 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Centerline?
Have you looked at Centerlines new wheels? I would find the wheel I liked and mill the center cap for the lock- outs.
Old 03-11-2004, 01:00 AM   #4
soleeagle
soleeagle's Avatar
Re: wheel selection sux!!
I was thinking the same thing myself. Everyone around here has those wheels. Thats why I bought a set from Jegs that were not made for lockouts and took the 2 caps to work and milled them out to fit over the lockout.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 03-11-2004, 10:33 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Look at Weld Racing they have a good looking series for 4wd trucks...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-11-2004, 11:32 AM   #6
Grim Reaper
I'm in the same boat.
See the problem he has a lot of the current trucks have a cenetral lock so the hug is small like a 2wd.
8 Lug selection just sucks to begin with if you looking for a real HD wheel. D and E rated tires are narrow. The stock factory rim is 6.5 inches.
I am about to give up and go with either the MT style like at the top or go with a OutlawII. I can get both of them in the weight rating I need. I can also get matching rims for the Airstream the truck pulls.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 03-11-2004, 12:05 PM   #7
cochino12
cochino12's Avatar
Re: Re: wheel selection sux!!
I guess I need to find a place that will do that for me. Anyone know what the center bore needs to be to clear the hubs? thanks for all the help guys
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-11-2004, 12:45 PM   #8
Grim Reaper
Re: Re: Re: wheel selection sux!!
This is for the jimmy right?
BE CAREFULL on theoffsett. The 88 up trucks are mor of a fwd offset. You want something 4 inches or less back space. \
The other problem is these trucks are hub centric from the factory. The newer trucks are as well BUT their hub diameter is smaller. If you can it would be best to machine it so be hubcentric again. I didn't drive my truck today so I'm worthlesss on a measurement.
Grim-Reaper
Old 03-11-2004, 12:58 PM   #9
cochino12
cochino12's Avatar
Re: Re: Re: Re: wheel selection sux!!
It is for the Jimmy. I am unsre what offset to get, I like the tire to sit about one inch outside the fender. Weld Wheels lists the center bore between 3.6 and 4.6, is that the right measurement for the hub? What does hub centric mean?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-11-2004, 01:08 PM   #10
Grim Reaper
Lug centric = lug nuts center the wheel.
Hub centeric= hub centers the wheel.
What width rim are ou going with?
You going to wheel it?
What size tire?
I'm running a 15x10 rim with a 35x12.5 tire. The tread is just under the fenders on the front but the sidewalls buldge out. The rear tracks 3 inch's less so the side walls are not as far out.
Not sure if this will let you direct link. This has a shot down the sied that you can et an idea of how the tires is to the body.
http://www.coloradok5.com/stcreview/stc9.jpg
If not it's in here.
http://www.coloradok5.com/stcreview.shtml
Here is a side shot. Only one I have on my work computer.
Mrs Reaper driving.
Grim-Reaper
Old 03-11-2004, 01:09 PM   #11
Grim Reaper
Ohh and that's a 4 inch back set wheel. JUST clears the tre's on the tie rod.
Grim-Reaper
Old 03-11-2004, 01:29 PM   #12
cochino12
cochino12's Avatar
I will be running a 33*12.5 on 15*10 wheels. Not much offroad just some light trails if that, its just a DD. Thanks for the help
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-11-2004, 01:45 PM   #13
Grim Reaper
4 inch is what you want then for a 10 inch. It will keep the airborn crud down and it should keep you from getting hassled by the man.
If you were running more trails then go with a 8 inch. Helps keep the bead from poping at lower pressure if your crawling.
We need to hook you up with Steve and TJ.
They go wheeling every once in a while.
Here is a nice shot of steve on a sunday drive.
Grim-Reaper
Old 03-12-2004, 01:08 AM   #14
soleeagle
soleeagle's Avatar
When I machined my center caps out I made the hole 3.5 inches. It was snug when I put them on and wish I would have went at least an 8th larger. Most of the newer rims do not have the hole big enough. I got lucky and the ones I chose had a hole in the rim big enough, just the cap had to be milled. I hope this can help you. I think my back spacing was aroun 3.75" too.It only has about 1/4 inch from the back of the rim and the tie rod.
Chuck
Old 03-12-2004, 11:14 AM   #15
Grim Reaper
Good point about the back spacing. My rims are stamped steel. A aluminum wheel is probably going to be a little thingker where it's near the tierod. 3.75 or 3.5 might be a better choice and guearantee no fitment issue.
Grim-Reaper
Old 03-13-2004, 12:38 PM   #16
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
cochino,
Summit has $20 in Summit Bucks for each Weld Stonecrusher wheel you buy. (says so in the front cover of the March-April Edition)
Just a thought.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 03-15-2004, 05:38 PM   #17
cochino12
cochino12's Avatar
Is there any way to get away with a 5" backspace? Probably not I just found some centerlines for a cheap price.
wheel link
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-15-2004, 05:47 PM   #18
Grim Reaper
Re: Re: Re: Re: Re: wheel selection sux!!
wheel link
That's a current back to 88 truck offset. Hmmmmm It might fit but it will be close. It will tuck them up under the truck.
Grim-Reaper
Old 03-15-2004, 11:55 PM   #19
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
I second that notion. Ive been trying to find something different than everybody else had on their 73-87, but all the wheels that are different, you cant get a centercap with a hole in it.
grrrrr....
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 03-16-2004, 12:05 PM   #20
Grim Reaper
Well I made a decision on what to get for the 3/4 burb last night.
We tow with it and it has a set off good Michelin's E rated hwy tires on it with a easy 20k left on them. they are a 235 85 16. Big time limited us in wheel selection. Have to go with a 16x7 max. Not much in that range with a 3k or better weight rating. It was down too the outlaw II (055) or the 589 knock off's in the first post. going with the 589's.
Also decided on the rims we are going with on the camper. they sort of look like OutlawII without the rivets. Nobody makes a OutlawII style with over a 1900lb rating and that would be at max weigh if we did that. www.Rjays.com has a set of aluminum mods with a 2540 weight rating for $92 each shipped. http://www.rjays.com/Wheels/hi-spec-wheels-01.htm
Grim-Reaper
Old 03-16-2004, 03:39 PM   #21
cochino12
cochino12's Avatar
post some pics once you get them. I think I have given up, I am going to have to go with the same damn wheels everyone else has. I cant find the width and the offset in any wheel under $350. I can get a full set of 4 eagle wheels shown above shipped to my house for under $375.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-16-2004, 10:49 PM   #22
Grim Reaper
Where from? That's a better price then I have found local.
Grim-Reaper
Old 03-17-2004, 12:08 PM   #23
cochino12
cochino12's Avatar
link
they are also on ebay for $380 buy it now
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 03-17-2004, 01:02 PM   #24
Grim Reaper
Thanks! I'm all over that.
Grim-Reaper
Old 03-17-2004, 01:23 PM   #25
cochino12
cochino12's Avatar
check the ebay auctions first!!! I just saw a set they sold for $340 shipped.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Thread Tools
Display Modes
