Old 03-13-2004, 07:57 PM   #1
too much stuff
Roadtrip!
too much stuff's Avatar
Parts value and ?'s
Just looked at a 68 3/4 ton 2wd. Engine is 350 4bbl, turbo 400 tranny, and 3:73 posi-traction. First of all, does this set-up seem correct for a 68? Next question, The rear end looking from behind is just a big round cover with 10 bolts around the cover and a drain plug about half way up the cover. According to the glovebox tag it reads Posi traction axle in one spot, and 3:73 gears in another spot. What kind of rear is this, and what is it worth? Any input is good. Thanks...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-13-2004, 08:51 PM   #2
Vince M
Vince M's Avatar
By your description the rear end sounds like the Eaton 3/4 ton FF axle. Some things I've not heard of though. The Eaton didn't come with a 3.73 as far I as know. Lowest ratio was a 4.10. But you never know. And with posi also.
Same again... as far as I know the 350 wasn't available in 68. Let us know what you find out anyways.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 03-14-2004, 06:38 PM   #3
too much stuff
Roadtrip!
Still thirsting for knowledge. sakohntr, longhornman...where you guys hiding?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-15-2004, 11:51 AM   #4
too much stuff
Roadtrip!
TTT Opinions are welcome also.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-15-2004, 11:53 AM   #5
Burnsman
Chevy Freak
Burnsman's Avatar
truck
I didn't think the 350 came out until 1969. But, I could be wrong.
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 03-15-2004, 12:09 PM   #6
Woody
It should have come with a 327 engine, not sure about the rear end.
Woody is offline   Reply With Quote
Old 03-15-2004, 12:44 PM   #7
griesel72
griesel72's Avatar
I thought that the 350's first year in our trucks was 69, but not positive.
Good luck
David
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
Old 03-15-2004, 08:55 PM   #8
too much stuff
Roadtrip!
He told me it is a 68, and definately has a 68 front clip on it. I could not read the vin in the glovebox, but could read where it said 350 engine. It also said chevrolet custom on the outside of the glovebox door like a 69 and newer. Possible to be a late 68? Still wondering about the rear end also.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-15-2004, 09:05 PM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
Could it possibly be a mismatched glove box door?
No 350 in 68 and a 3/4 ton rear would either be 4:10 or 4:56 dana or Corp, unless BB auto, then it's a 3:54 dana.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-15-2004, 09:14 PM   #10
too much stuff
Roadtrip!
The glove box door seemed to match everything on the truck. Only other option is someone added a different front clip at one time. The guy that has it now has owned it for over 20 years. Even if the clip was changed, the 3:73 should still be original. Odometer reads 77K Which could be actual judging by the rest of the truck, however, i know it was painted at one time long ago.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-15-2004, 09:26 PM   #11
CPNE
Resident Curmudgeon
CPNE's Avatar
There are no full floater 3:73 rears I know of between 67-72. Are you sure it's a 3/4 ton? 3:73 is a half ton rear ratio.
Old 03-15-2004, 10:53 PM   #12
too much stuff
Roadtrip!
The diff does not look like any half ton stuff that i have. It has dog dish hub caps on it so i couldn't see how many lug nuts it had. It had tall narrow bias tires with 16.5 split rims on it. The diff cover was round and smooth.(other than drain plug)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Thread Tools
Display Modes
