03-14-2004, 06:08 PM | #1 |
Gear ratios
I've got a 70 Chevy shortbed, fleetside 4x4.
When I had the rear differential rebuilt, I was told I had 373 gears and they were considered "highway gears" I'm running a 2001 ZZ4 Corvette motor from GM, with 33 inch tires......Are these gears too high for this application? The motor never seems to run at its optimum RPMs. Looking for some input, good or bad. Thanks, Bradleyworld |
03-14-2004, 07:56 PM | #2 |
Do you have an OD transmission in it? If not the 3.73 gears are probably good. I have 3.42 gears and can't use Overdrive right now because 3rd gear only turns about 2200 rpm on the highway and I get about 16mpg like that.
With a 1:1 transmission ratio, 3.73 gears, and 33" tires you should be turning about 2400-2500 rpm which is good for fuel economy depending on your engine setup.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
03-14-2004, 08:26 PM | #3 |
Nope, no overdrive. I'm sure I could never use it if I did.
I don't have a tach(I know SHAME ON ME!) but it does seem to lug a little. Thanks, Bradleyworld |
03-14-2004, 10:13 PM | #4 |
3.73s and 33s are just about perfect for each other. also, the ZZ4 is not a Vette motor, its a GM crate engine that was never offered in any production vehicle.
03-14-2004, 10:16 PM | #5 |
3.73's and 33's are good to go
03-15-2004, 08:44 PM | #6 |
Thanks all.
Bradleyworld |
03-16-2004, 05:26 PM | #7 |
user # 2756
Of course from the factory the 3/4 tons had 4.10s and 4.56s with tires smaller than 33". My 70 has 4.10s and 33s and it keeps the RPMs up. My 71 has 4.56s and small 35s, not on the road yet, but the engine will be screaming soon! You could probably go w/ 4.10s and raise your RPMs a little. that ZZ4 will probably like it, turning about 2800 on the highway.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
Thread Tools | |
Display Modes | |
