03-14-2004, 07:07 PM | #1 |
hey v8 350 owners..... easy quick Q....
i have a 350 v8 chevy engine.....
any idea what oil filter goes on it? i'm questioning the results of the parts store.... cause the filter i took off doesnt match the one they gave me..... Phram PH5??? is what they gave me.... do you think the last place that changed my oil screwed it up and put on the wrong filter? thanks for the quick response! ciao! jewels.
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
03-14-2004, 07:17 PM | #2 |
Designated A-hole!
First off, I am sure you have heard it before, but don't put a Fram oil filter on it, go with a delco or napa at the least.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
03-14-2004, 07:20 PM | #3 |
ok, i think i got ahold of another board member which told me the same thing....
this is what gscotti had to say..... he said dont buy a phram, because they ten to let more particles through than most.... he also said that there are two filter sizes for a chevy v8 350 engine.... the first is the PH5 Phram size (or longer size)..... and the second is the PH30 or the shorter size..... but both will work.... it looks like the oil change place put on the shorter filter the last time i had it changed this winter..... i am makin a trip back to the parts store to dump off the oil, so i might just change out the phram for another brand while i'm there.... thanks krue! jewels.
03-14-2004, 07:24 PM | #4 |
I have two sets of filter in the garage, one is a GM-PF35 and a Napa which equtes to a PH25, the difference is the 25 is shorter hold a 1/2 QT and the 35 holds a QT. In the late model GM trucks they used a GM-PH51 very thin but longer than the 25 series held 1/2 QT oil.
03-14-2004, 07:35 PM | #5 |
Inline 69
fram also makes an "x2" filter which is a large capacity filter http://www.fram.com/ jeff
03-14-2004, 08:44 PM | #6 |
I know a Hastings is a LF 224.
03-14-2004, 09:09 PM | #7 |
The correct A/C number is PF-35 (longer, therefore more capacity)--as Martha USED to say "It's a good thing". I would use the A/C or Wix--JMO. I don't know if all the denigration of Fram is true or not, but I have always used A/C or Wix.
Stepsides look like real trucks! Smitty |
03-14-2004, 09:09 PM | #8 |
...i always went rule of thumb..ac delco 35 without headers...25 with headers...the shorter 25 is easeir to get on and off with headers
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
03-14-2004, 09:39 PM | #9 |
2A674 Tank Rat
A mechanic friend who built an engine for me a long time ago showed me the only difference in the filter lengths was open air space. Not a bigger filter. He cut one of each open and showed me this. He said the longer filter was intended for truck motors so people would pay a few extra pennies for it thinking they had to. But the shorter more common filter for Chevy engines would be fine and would make no difference. Just a preference thing really. I have always used the more common shorter filter on my trucks as I have with the camaro when I had it. I never heard about the "problem" with Phram /Fram filters. I'm not doubting or disbuting that. As far as the length of the filter I don't believe it matters. It hasn't mattered with my vehicles.
As far as changing the filter when you go back to the parts store, personally I wouldn't bother. But the next time you change your oil I would just put on the one you prefer. Just my opinion here.
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
03-14-2004, 10:10 PM | #10 |
Its Magically Delicious
ac delco PF1218.... its whats on my 350
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
03-14-2004, 10:25 PM | #11 |
71longbed---PF 1218 is a later # than they used on our old trucks--It's on my '96 5.7L I think Jewels is a '68.
03-14-2004, 10:28 PM | #12 |
oops ..sorry ... i guess my assumption was uncorrect
03-14-2004, 10:41 PM | #13 |
You might want to check out this study/test on oil filters.
http://minimopar.knizefamily.net/oilfilterstudy.html By the way NAPA oil filters are made by Wix. Another good filter is any of the ones made by Champion Labs ( K&N, Mobil 1). Better to run toilet paper than Fram, which by the way there used to be an aftermarket filter that used toilet paper
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
03-14-2004, 11:13 PM | #14 |
its all about the +6 inches
The toilet paper filters were better than any filter on the market today. Bummer you can't still get the kit. Kinda messy though.
The NAPA filter number (made by WIX as stated) is 1060 I think. The Fram is an over advertised POS. Our oil lab has proven this to me by pulling out the cut open filters that they have put away. The best for the dollar is WIX/Napa. Jewel's truck IS a 68, but her engine is a 76 if memory serves...the 350 shoulda givin it away since 307 and 327 were the only small blocks in 68. |
03-14-2004, 11:35 PM | #15 |
Neonlarry--thanks for the link to the study! Good stuff!
I wonder if somone has done a similar study on air filters--I have STRONG reservations about K & N filtering capability! http://motorcycleinfo.calsci.com/Filters.html
Stepsides look like real trucks! Smitty Last edited by smitty62; 03-14-2004 at 11:42 PM. |
03-14-2004, 11:43 PM | #16 |
Designated A-hole!
Hey Andy, I know where you can get a kit to use the TP filter, Edb has one on his truck. It's a bypass filter set up. I plan on getting one for my truck when I put a new engine in it.
03-15-2004, 01:57 AM | #17 |
Firefighter
Yeah, to go along with the Fram info a buddy of mine is a diesel mechanic for Case Equip. and he has seen several Frams inner filter material break loose and get sucked into the engines causing a rebuild!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
03-15-2004, 11:23 PM | #18 |
The 1218 has a anti-drainback valve. This is an excellant upgrade for any vehicle.
03-15-2004, 11:30 PM | #19 |
PF35 has been replaced by a PF1218
PF25 has been replaced by a PF454 AC also makes a 2qt spin on filter, but I can't remember the number. |
03-15-2004, 11:55 PM | #20 |
SLOW BUT SURE,BUT CLOSER
Try a PH16 Fram, used them for over 25 yrs and never lost a motor.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
03-16-2004, 12:26 AM | #21 |
What Ken Brown ^^^ and team roper ^^^ said.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
03-16-2004, 12:29 AM | #22 |
Try spinnin 4 rear tars
I run a fram filter... No problems here
ANd mine is a PH5!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
03-16-2004, 12:34 AM | #23 |
Sisyphus was my mentor!
WIX!!!!!!!!!
Get a wix ph# 51060. Thats the good one with an anti-drainback valve. I'll fit all smallblocks 68 up to i dunno when.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
03-16-2004, 12:39 AM | #24 |
Cut open that fram that you get, and go get a NAPA one, or a WIX...you'll never run a Fram again.
03-16-2004, 01:45 AM | #25 |
Hammer On!
passthebuck... you read my mind exactly. I only use Wix oil filters! And you are correct about the anti-drainback valve.
Aaron
1968 C20 Inline 6 250 SM465 4 speed 1968 K10 Inline 6 250 SM465 4 speed |
Thread Tools | |
Display Modes | |
