Old 03-16-2004, 12:14 AM   #1
bretwest
dual tanks
new to board. 78 k-10. i have a fuel pump starvation problem. changed pump without doing proper troubleshooting only to find out i wasted my money. ? do gm fuel tank selector valves have a filter in them? thanks
bretwest is offline   Reply With Quote
Old 03-16-2004, 12:20 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Welcome to the board The valves don't have a filter in them. Here's some things to do to help trouble shoot. Does your gauge move when you switch the tanks? Have you been kicking or moving anything near your fuse block panel? Just a few questions to help diagnose.
Now here's a couple ideas:
On your interior valve switch replace it. To me it sounds like you have a bad switch. I got mine with cover for like $10 from the dealer. Don't use the Auto Zone stuff. The dealer is a couple bucks more but why waste on something that isn't to GM specs? To take off the switch and cover the 2 nuts have to be taken off the rear of the cover behind the dash. Best way is to take out the ash tray and it's much eaier to get to then. Don't use the Auto Zone stuff. The dealer is a couple bucks more but why waste on something that isn't to GM specs? While you're there with the plug off let's see if we're getting power to where it needs to be.
From the 3 o'clock position this is #1 wire then so on till #5 for reference.
#1- Ignition wire (pink w/ black stripe)
#2- Valve wire (lt. green)
#3- Tank Aux. (lt. blue)
#4- Gauge (tan)
#5- Tank Main (tan w/ white)
#6- Not used
With the ignition on you should get power with the #1 slot. If not check the pink w/black wire by following it to the fuse panel. Mine was connected with a male spade connector to a IGN slot. This way it's only powered when ignition is on (neing not running). Also you should have a light when testing for the #4 gauge as well (assuming it the #1 is hot).
If this doesn't solve it then take a test light to your fuel valve itself. It is located on the passenger side close to where the cab and bed meet. There are 3 different setups on the valve. They are 3 ports (fuel) 1 wire, 6 ports 1 wire (mine) and 6 ports 6? wires. You need to see which one this is. On the 3 & 6 ports with 1 wire, the green wire, attaches to a bolt coming from the valve itself. This is what powers the valve to flip from the one tank sending hose to another. When you have the selector valve on the left side (with ignition switch on and for safety engine not running and emergency brake on) the green wire will have power (where test light comes in). When you have it on the right side of the switch the wire will have no power. This is why I like to run on my right tank more often than my left. Now if you don't have any power to that switch under the bed, you need to backtrack (next section). If you do have power then you need to test the valve itself. With the ignition on engine not running and emergency brake on (safety first) take the green wire with connector to the "bolt" that is the connection on the valve itself. As long as you have power (with the interior switch flipped to the left side) you should hear the valve turn to the left tank. It sounds like a "click" almost. If you have power to the green wire but the valve is not changing tanks this is your problem. Replace the valve (I got mine for $70 from a AC Delco parts warehouse) and while you're there replace all the fuel lines as well. It's cheap insurance. Just make sure to label the hoses so you know which goes back on where. With 6 hoses on mine it was a job to make sure everything was on right.
On the firewall driver side look for a 4 wire harness with a bulk connector (looks like a connector that has a rubber boot) It will have 2 tan wires a green and a lt blue wire. This is where the tanks and selector valve wire come from the interior switch. If this is tight and no corrosion then we'll need to rethink this. Hopefully this works.
If you have a 6 wire then let me know and I'll try to find a spec for that then. I have't messed with that wire harness yet at the tank selector valve itself.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-16-2004, 01:13 AM   #3
bretwest
thanks. i do have power on the green wire to the valve with the switch on L.H. didn't check R.H.. also didn't here any click of valve motion when removing and reinstalling green wire. you seem pretty knowledgable judging from reading your other responses. what is your take on removing the return line, capping and buying vented gas caps. i'm going to pull the valve tomorrow after work.
Old 03-16-2004, 11:40 AM   #4
79BIG10
79BIG10's Avatar
Thanks for the kind words I've owned a few of these trucks and learn something new with each one (especially this one). On the return line from the fuel pump I installed a bolt and hose clamp on it to block it off until I can get a different fuel pump. It runs a bit richer but I adjusted the airflow inlets on the carb to compensate. On the return line on the valve I did the same just to be safe. I also have taken off my charcoal canisters since i'm no longer needing testing for emissions.
I bought a set of locking vented caps from a local parts store here. I had to order them and took about 2 days to get in. No problems yet and been about a year.
On the valve problem you don't need to take it off just make sure that when you test the wire that the ignition power is on but the truck is not running. Let us know what you find out and hopefully it's a easy fix.
Thread Tools
Display Modes
