Old 03-18-2004, 08:37 PM   #1
72'BBGMCSGCC
Question how do I rebuild calipers?
I need to rebuild the front disk brake calipers on my 72' 3/4 and was wondering how to do this? Thank you. Dave
72'BBGMCSGCC is offline   Reply With Quote
Old 03-18-2004, 08:47 PM   #2
rolson1039
most suto parts stores sell the rebuild kits and autozone sells the tools
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 03-18-2004, 08:50 PM   #3
walker
walker's Avatar
Go buy a rebuild kit. Pull the piston out the front, clean everything up, put on a new o-ring, install the piston, install the dust seal, reinstall caliper, bleed, drive away. That is the most basic instruction. You may need to hone your cylinder as well. IMO go buy a brand new one, not rebuilt, they seem to last way longer than a rebuild.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 03-18-2004, 08:51 PM   #4
72'BBGMCSGCC
What's involved and what do I have to do to rebiuld the calipers?
Old 03-18-2004, 08:52 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
rebuild or cleanup? Rebuiding is really simple. Take the calipers off, remove the brake line, plug the hose, remove the pads, pull the piston, check for rust, dirt, and moisture, remove the O-ring and replace. Put it all back together. Put in fresh brake fluid at the resevoir. Have someone pump the brakes and hold the pedal on the 3rd pump. Open the bleeder screw, tighten back up. Do this until a solid stream of fluid comes out of the bleeder screw. Don't forget to check the resevoir ever now and then. You don't want to empty it out.
67Fleetsidedream is offline   Reply With Quote
Old 03-18-2004, 08:52 PM   #6
72'BBGMCSGCC
sorry walker you must have replied just before my post where can I buy new ones? Thank you. Dave
Old 03-18-2004, 09:55 PM   #7
cdowns
cdowns's Avatar
you can buy brake parts at the autoparts store
Thread Tools
Display Modes
