Old 03-20-2004, 09:51 PM   #1
chevy lover
HMMMM Chevy
chevy lover's Avatar
lifting a diesel
I am wanting to lift my '82 GMC which has a 6.2l diesel in it. I need a good set of front springs that are going to take the load. The diesel is about 300 lbs. heavier than a sbc I think. So I need a spring that will take the weight and give me a 4" lift. Anybody got any suggestions?
68 Chevy C10 swb(under construction)
82 GMC K1500 6.2l diesel (daily driver)
77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________
Mike
chevy lover is offline   Reply With Quote
Old 03-24-2004, 11:49 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Go with rough country springs they seem to have one of the highest spring rates. I also believe Rancho has high spring rates. Stay away from soft or ez ride springs. My 2" heavy duty tuff country springs netted about 3" of lift, you could try them (they have 2 and 4" HD springs).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-24-2004, 11:35 PM   #3
The Dude
you could probably just use the next size spring. ya know if its a half ton, use a 3/4 ton lift spring, if a 3/4 ton usea 1 ton leafs.
The Dude is offline   Reply With Quote
Old 04-15-2004, 09:13 PM   #4
72bigblock4wd
I have a '72 K10 that's getting a 454. I ordered a 4" lift kit from Superlift with Heavy Duty front springs designed specifically for a Big Block or Diesel truck. I bought mine on ebay from Davy1445.
72bigblock4wd is offline   Reply With Quote
Thread Tools
Display Modes
