Old 03-22-2004, 09:01 PM   #1
moodyholler
moodyholler's Avatar
Steering Box?
OK I've rebuilt the front axle, new bearings,seals,axles, and balljoints, Replaced the tierod ends and now have worked my way to the slop in box. Too much to adjust out. WHo makes a p/s box new or rebuilt and can I get one with variable ratio steering. Thanks,moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 03-22-2004, 10:20 PM   #2
blazerholic
I am a Gov't Mule
blazerholic's Avatar
I'm pretty sure I've seen 'em in LMC's catalog. Pricey too if I remember correctly
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 03-23-2004, 12:04 AM   #3
skid
Moodyholler
I did everything you did as well and still had slop. I bought a rebuilt steering box from LMC, along with a rebuilt pump and new hoses. Figured that I might as well use all rebuilt items. Turns out that my return hose had just about worn through where it rubbed on the frame! Good thing I replaced it. I also replaced my rag joint with a new one.
My steering isn't perfect yet. My rear axles have slop between the c clips and the pinion shaft. That is steering the rear of the truck a bit. I replaced the axles with new ones (the old ones floated more than 1/8th of and inch!), but the rest of the diff is worn, so I still have way over the recommended amount of end float. Plus my springs and shocks are saggy. Sigh... still a lot more work to do.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 03-23-2004, 12:06 PM   #4
69k5
you can buy new ones at autozone and places but they are kinda pricey. might check into rebuilding it as well.
69k5
69k5 is offline   Reply With Quote
Old 03-25-2004, 09:15 PM   #5
earnhardt221
huh,re-building a power steering box? MAJOR PAIN IN THE ASS! trust me
earnhardt221 is offline   Reply With Quote
Thread Tools
Display Modes
