Old 03-29-2004, 09:03 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Couple of ????
Can I run sway bar's with air bag's? (front and rear)
Those of you who have shaved your door handle's what kit did you use (autoloc etc etc) and if you had the choice what kit would you use..
Thank's for any and all reply's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-29-2004, 09:31 PM   #2
mooneyes
mooneyes's Avatar
...can't answer your ?..but sweet avatar of wild willie's winged express!!!!
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 03-29-2004, 10:26 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thank's I wish I had the pic of willie going sideway's with only one hand on the wheel..
MEMBER #6377
Project "7DEUCE"
Old 03-29-2004, 10:54 PM   #4
Faster_than_you
I tell you what, you can aim this guy he is a very knowledgeable person on custom things for cars and trucks. I talked to him about any question I may have about my truck. well here is his aim name hyprformance he even knows of this kit that you can knock on your window with a personal code and it opens your doors. also ifcustoms.com they have a special running on shave kits. for I think 139 or something. ifcustoms.com actually had an article in truckin for something, well they had been the builders of the parts they used in the article.
usually will run you around 380 for installation of the kit, and about 400 for just the labor and maintanence to shave your door. about 175+tax is normal here in va
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 03-29-2004, 10:55 PM   #5
Faster_than_you
sorry that is 175+tax per door.
~Christopher L. Orr
Thread Tools
Display Modes
