Old 04-06-2004, 03:23 AM   #1
lost_66
Please look......
i was surpine that 73 to 87 gauge cluster has differnt style
for mph and rpm is that factory made that way???? pls look link..
http://cgi.ebay.com/ebaymotors/ws/eB...472269871&rd=1
lost_66 is offline   Reply With Quote
Old 04-06-2004, 03:57 AM   #2
Russell
Professional Grade
Russell's Avatar
Cool!
I like it!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-06-2004, 09:38 AM   #3
Jonboy
Slots go on anything!
The speedo and tach are out of a 70-73 Trans Am. It looks pretty trick in there. I had seen late 70'2 Camaro tachs put in 67-72 clusters before, but I like this better.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-06-2004, 11:17 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
The question is will it work? We know it's got an AMP gauge in it, so it's not a direct fit in any thing past 76(?). I can't imagine just popping those gauges in and them working correctly.
Unless you are a gambler, I would steer clear of it...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-06-2004, 11:58 AM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
It should work. GM (as strange it may sound) were pretty "standard" on their connections. The tach for the F-body will have the same leads and the Speedo only needs a cable. I am just curious as to why he didn't indicate that they weren't real 73-87 gauges. Plus the fact that the speedo and Tach don't match you other gauges.....
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-06-2004, 12:14 PM   #6
cochino12
It followed me home?
cochino12's Avatar
160 mph speedo in a truck just seems kinda dumb to me. I put a 100 mph and its a waste too.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-06-2004, 12:22 PM   #7
77bowtie
I don't know about that! I outrun my 100mph speedo quite regularly.
77bowtie is offline   Reply With Quote
Old 04-06-2004, 12:35 PM   #8
crossy
Oh,you can't buy that new
crossy's Avatar
I'm too tired right now(night shifts again) to get into all of this but Don't fall for it . I've measured those early T/A gauges and MANY many other gauges and nothing factory is as large as ours. he is not showing close enough of pics to see the gap that may be all around the opening. plus there is no 'slight' rewiring in the 73-87's . he has the typical unknowing statement of 'fits all 73-87's' and I can't tell you enough of how wrong that is . He has others up for bid and one has the 7K tach in it and he says it's in perfect working order and it's missing two mounting tabs , one of them a major mounting point, and it's guide for the gear indicator string is broken completly out and that can't be fixed. Plus no pics of how cobbled up the back side of them is . 'caveat emptor'.
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 04-06-2004, 12:42 PM   #9
cochino12
cochino12's Avatar
Hey Crossy I wanted to thank you for the write up you did on the factory tach stuff. I just added one and the info you put on 73-87.com really helped a lot.
Adam
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-06-2004, 12:58 PM   #10
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Here is one installed:
http://www.cardomain.com/memberpage/563861
The site says "'79 Trans Am speedo and tach (use a Dremmel tool and some RTV to do this!)."
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-06-2004, 10:31 PM   #11
lost_66
interesting!!!......
Old 04-06-2004, 10:38 PM   #12
apstguy
LED King
apstguy's Avatar
My 85 mph gauge is too small. I find myself often at 85 or above in the black space on the freeway.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 04-06-2004, 11:02 PM   #13
swervin ervin
You get what you pay for
swervin ervin's Avatar
I wonder where this idea came from?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 04-07-2004, 11:07 PM   #14
lofat
Rollin' Member
lofat's Avatar
where is a good 'cutting edge' pun when you need one.
:: 1977 C10 cheyenne ::
:: 1973 new yorker brougham :: for sale - $1,500
lofat productions
lofat is offline   Reply With Quote
Old 04-07-2004, 11:39 PM   #15
Russell
Professional Grade
Russell's Avatar
I dunno about you cochino -- but even I can peg my 100 mph speedo, and thats with a totally stock truck with a half 3.73 and half 4.10 rear end, lol
Old 04-07-2004, 11:58 PM   #16
bigblock73
yeller
bigblock73's Avatar
As the old sayin goes, "its better to have it and not need it, than to need it and not have it".
Most aftermarket tachs are 100+, so unless you want to use a stock GM one, there isn't much you can do.
I wanted to thank Dave too, the tach article is great. It still needs some tweaking, but he and I can work on that. I have also been adding example pics as I find decent ones to use. I would ideally like to find an example of every year or different variation.
Here is the link in case it has changed since the last time anyone was there.
bigblock73 is offline   Reply With Quote
Old 04-08-2004, 06:43 AM   #17
TwinTurbo
TwinTurbo's Avatar
Adam
wow, I have a 85 mph speedo and my needle is pegged all the way in the right bottom almost all the time...wanna trade?
TwinTurbo is offline   Reply With Quote
Thread Tools
Display Modes
