Old 04-08-2004, 03:58 PM   #1
OrangePride
Can't find what's causing vibration
When driving between approx. 45 and 60, I get a vibration. It doesn't really seem to be in any sort of rythm, just a sort of shaking feeling.
I'm sure it's not the engine or tranny because it did this before they were both replace. Also most front end parts have been replaced and I don't feel the shaking in the steering wheel. Could it be the carrier bearing? How do you tell if they are bad? Could worn shocks cause this?
If it's not broke, make it better!
OrangePride is offline   Reply With Quote
Old 04-08-2004, 04:10 PM   #2
jku72
Drive shaft.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 04-08-2004, 04:15 PM   #3
jhow66
jhow66's Avatar
Have you checked your u-joints (3)? The bearing itself should not cause a vibration-only if the rubber cushion is busted. To check just see if you can move the driveshaft in the rubber mount. (it will move some but should not be free from rubber. Worn shocks would cause more of a bounce of the wheel up and down.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-08-2004, 04:29 PM   #4
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Sounds to me like you may have slung a wheel weight. Get the tires balanced and see if it disappears.
67Fleetsidedream is offline   Reply With Quote
Old 04-08-2004, 04:43 PM   #5
RON WOODGEARD
Resident Young Old Dude !
Being that it starts at a speed (45) then quits at a speed (60) I have a tendency to believe it's rear tires. (If you don't feel it in the steering wheel) Worn shocks can intensify the shake.
When I needed my driveline balanced, It was almost a "ROAR" ( kind of like aggressive tires do) And when U-joints are going, The vibration is usually on the Let off of the gas pedal...and the vibration from both of these is felt throughout the vehicle..
RON WOODGEARD is offline   Reply With Quote
Thread Tools
Display Modes
