04-12-2004, 02:31 AM | #1 |
oil on top of manifold?????
i have an edelbrock carb and intake.the other day i noticed right below the carb i have pools of oil on the intake.any ideas why and how its there
springfield illinois 2003 custom (harley)built from scratch 68 swb |
04-12-2004, 02:39 AM | #2 |
Southern Bowties
Could it be oil seeping up the intake bolts?
1972 Cheyenne 350/350 |
04-12-2004, 04:55 AM | #3 |
-Chris
i was going to say the same thing. Try tightening up the intake bolts a bit, but not too much depending on if you have aluminum or iron. Had the same thing with mine.
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
04-12-2004, 06:44 AM | #4 |
Check your PCV valve it might be stuck open and pulling oil from the valve cover.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
04-12-2004, 08:51 AM | #5 |
KEEP ON TRUCKING
pull the bolts out and coat them with gasket sealer and reinstall
72 cheyenne 2wd lwb 71 k20 sons bassett va |
04-12-2004, 09:15 AM | #6 |
I'm with shadetree on this one. Had the same problem till I pulled the bolts, put some sealer on the threds and reinstalled them--Fixed!
Thread Tools | |
Display Modes | |
