Old 04-12-2004, 03:27 PM   #1
68jimmy
68jimmy's Avatar
Removing turn signal switch
I recently picked up an auto steering column and I'm in the process of cleaning it up. I was wanting to remove the turn signal switch assembly, but the hazard switch is making it just a bit difficult...
From what I can tell you can't remove the hazard switch, so how do you get it out (the assembly) without breaking it (hazard switch)?
thanks!
68jimmy is offline   Reply With Quote
Old 04-12-2004, 03:36 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Disconnect battery first!. Then push in button to gain clearance. It's tight but will wiggle out with it pushed in.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-12-2004, 03:46 PM   #3
72moneypit
72moneypit's Avatar
On my 72 tilt column, the hazard switch knob unscrews from the turn signal assembly just like it was a regular screw.
Paul
72 Cheyenne Super Custom Camper
greenaz@hotmail.com
72moneypit is offline   Reply With Quote
Old 04-12-2004, 04:12 PM   #4
68jimmy
68jimmy's Avatar
I'll give a try one more time!
thanks.
Thread Tools
Display Modes
