Old 04-12-2004, 10:25 PM   #1
NPilot1975
NPilot1975's Avatar
Laying Rockers on 20's
How much of a bridge in the rear frame and what set-up on the front do you use in order to set the body on the ground using 20" rims? Has anyone done it?
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 04-12-2004, 10:33 PM   #2
Glen
I think the proper way to do that would be to body drop it. Hacking the front frame/suspension up that high will ruin the geometry and you will have to cut a tunnel for the driveline thru the cab anyway to set things up properly.
Can you do it without bodydropping...yes, it will be easier in the long run and cause less problems if you channel the cab over the frame.
Glen is offline   Reply With Quote
Thread Tools
Display Modes
