Restoring instrument cluster
Whats the easiest way( if any) to restore an instrument cluster. Ive heard talk about it but not sure how to do it without breaking anything. thanks
Designated A-hole!
What are you wanting to do to it? New bezels can be had fairly cheap from some of the vendors that hang out here.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
They aren't too hard to take apart.. I broke mine down, cleaned it up and put it back togather, didn't run into any of those "Suprises" where springs etc jump out .. and you go "Oh Sh#$"..
You can match the paint on the needles, but I am not sure about the greenish/white background paint..
1972 Cheyenne Olive over Dark Green, Longbed 402BBC, TH400 |
You can do a search on it....I took the advice of others: Wal-Mart has it : Krylon paint, fluorescent orange, and the pale green color. Both colors matched very well- I just did mine yesterday. Looks almost new and it wan't hard.
1971 GMC LWB 350/350--SOLD 1970 Chevy LWB 350/350--SOLD 2000 VW VR6! |
Removed mine, cleaned it up, repainted where necessary, repainted needles, cleaned inside of lens. Much easier than working on a heater coil, and like 402GLH said, no snakes...
While the cluster is out, good time to check wiring, wiper and washer pump motors, leaks in firewall, defroster duct, vacuum out crud. ![]()
Bob 68 C20 Camper Special Last edited by Pilgrim; 04-13-2004 at 08:36 PM. |
its all about the +6 inches
Something you can do while it is apart, is painting all that funky green white. It'll give off more light, and in a brighter color at night. You'll actually be able to read your guages at a glance instead of doing a double take.
Here is a pic pirated from Josh. |
Speed Limit = Floorboard
Hmm...everytime I think about doing something and might ask a question...its already on here...lol. I love this website. quick question...what is the gauge next to the the oil pressure that is blank?... Its not coming to me what it could be. I was thinking volt meter or auxilary fuel tank gauge?...and what are the lines on the side of the fuel guage?
1971 C20 350, 4-speed - Sold. 1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project. "Build for torque, horsepower will follow" |
Vacuum.
And mine isn't blank! ![]() Brian |
The 'blank' hole is used for a vacume guage or an air pressure guage on the C/40 and bigger trucks, but in the light duty rigs, they were always blank.
As for lines on the side of the fuel guage... ![]() |
Roadtrip!
![]() Join Date: Feb 2003
The lines on the side of the fuel, are you referring to the idiot lights for brake and temp?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Is it a big deal to add a vacuum guage? Is there anyplace where one could be ordered? I'd love to add one. LMC Truck lists all but the vacuum guage.
72 Cheyenne Super 4x4 SWB |
Navel Inspector
My oil pressure guage is loose after I put it all back together. I don't know if this is common or if you will run into the same problem. I go to tighten it and find that it is all crooked afterwards. I need to remove and restart. What type of guage cluster do you have?
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
#13 |
I put a new bezel and lens in mine. If you reuse your old lens, get some rubbing compound at a car parts store. That will take out most of the scratches and shine it up some. The white stripes on the guages will smear if you use a wet rag to clean them, but they will clean back up with a dry rag imediately after.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#14 |
hmm thats cool. I wasn't refering to the idiot lights...to much stuff.... I ment the lines next to them on the side.
#15 |
Careful, they attack...
There is no purpose to the lines, just there for looks. They don't go to some super obscure guage that no one has. It would look lop-sided if the speedo has lines all around and the fuel gauge didn't.
#16 |
Go to www.durangedesign.com and get theoverlays for the gauges. Ask for the black with white lines and he will make them for you, no problem. That is what I did and mine look brand new. The lines on the overlays aren't perfect, but they are not bad for a driver. Then just paint the needles orange and you are good to go. I also recommend painting the back of the instrument cluster white, it really improves the brightness!
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#17 |
SKINNY TIRES RULE!
jorgensensc - can you post pics of your gauges with the overlays? I have a tach dash that I'm working on but some of the gauges have surface rust, including the tach. I could easily swap the rest of the gauges with my current cluster but I would still have some surface rust on the tach. I was thinking about getting their white face kit, but I don't really want white gauge faces.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#18 |
sure, I willl post them tonight when I get home.
#19 |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
Just a quick thing about durange designs, they were banned from this board for spamming, and refusing to pay an advertisers fee.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
#20 |
I was unaware of that Josh
![]() Shawn
#21 |
SKINNY TIRES RULE!
Josh, I'll avoid their products then. Do you know of any other companies that make a similar product?
Thread Tools | |
Display Modes | |
