Old 04-13-2004, 07:33 PM   #1
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Red face Brake drum adjustment
Hi Everyone,
Even though my truck is a '62 the drum brake adjustment should be the same as the '67s-70 trucks right? If so what should be the propper brake adjustment (star turns)?
TIA,
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 04-13-2004, 07:57 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Should be the same. Adjust the brakes to where the pads are barely rubbing the drum.
67Fleetsidedream is offline   Reply With Quote
Old 04-13-2004, 08:05 PM   #3
WB72
Before and After
WB72's Avatar
I just usually get them close to the drum, and then use the adjusters to do the rest automatically.
Just roll the truck in reverse(slowly). and hit the pedal, to get the brakes to grab the drum, and it in turn muves the lever onto the adjuster, do this a few times, and the will be set perfectly every time. Evrey time you hit the brakes in reverse, it will tighten up the adjuster, but only when there is enough room for the brake shoes to move.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 04-13-2004, 11:59 PM   #4
gman
I just did my drums over the weekend and am wondering if it is normal for the drums to slightly contact the brake shoes after the auto adjust is done. With tires off the ground, when i spin the wheels there is just a hint of the shoes contacting the drum at one spot on each wheel. Is this anything to be concerned with? Thought it might be relavent to "Chevyboy"s question also.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 04-14-2004, 12:02 AM   #5
gman
By the way, I did mine just as WB72 stated and it worked just fine.......other than the small bit of rubbing of the new shoes.
Old 04-14-2004, 12:23 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
slight drag is normal.
Thread Tools
Display Modes
