11-26-2004, 04:45 PM | #1 |
my truck after drop (updated pics)
heres some pics of truck after i lowered it 2.5 inches in the front and 4 in the rear. stock shocks. new frontend. i also put new exhaust on it but damaged the passenger side already...truck has a rebuilt th350 now and we just put an edelbrock performer rpm with a holley 600 cfm carb on it. i had a nice polished 105 amp alternator but faulty wiring messed it up ALREADY. im pissed and hoping i can order a kit to fix it. i had to fix all the wiring goto the alternator until i get my new front lightsharness in. i also put a 275/60/15 dunlop g/t qualifier on the back of the truck. still 255/60 on the front. im going to get matching tires front and rear eventually. im sticking with a 255/60 dunlop g/t qualifier on the front when i get them. the interior is up next with new floors, sound deadner, carpet, then i get my system installed. 2 12's are going behind the seat where the gas tank used to be. oh the ghetto filler neck door and cab patch will be fixed when i save up and have the body work done to them...
and i have two reproduction goodmark doors waiting to go on after i do the floors and rockers...
70 longbed 496/th400/Ford 9" Last edited by dinnut; 11-26-2004 at 04:49 PM. |
11-26-2004, 04:48 PM | #2 |
heres a before pic of the truck and what the engine looks like now
70 longbed 496/th400/Ford 9" |
11-26-2004, 04:51 PM | #3 |
Looking real nice so far. What wheels are those?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
11-26-2004, 05:01 PM | #4 |
PROJECT 7DEUCE
Looks good dinnut did you finally get the wheels to stay on the truck?if so what was the problem???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-26-2004, 05:02 PM | #5 |
no idea on the wheels. yeah havent had any problems so far. i think the lugs on that wheel might have been left loose for some reason. or it could be that that wheel had a horrible wobble to it because the front end on that side was in horrible need of replacement and might have vibrated them loose. i have all new lugs now and i make sure they are tight.
70 longbed 496/th400/Ford 9" Last edited by dinnut; 11-26-2004 at 05:05 PM. |
11-26-2004, 06:04 PM | #6 |
Nice truck!!
11-26-2004, 07:32 PM | #7 |
Looks real good!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-26-2004, 07:48 PM | #8 |
How do you like the drop so far,and would you go more next time? I'm planning to drop my first truck soon,and have not decided how much yet.
11-26-2004, 08:37 PM | #9 |
Nice truck
Good looking truck. It makes the rest of us get motivated to do things to ours. Keep up the good work. Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
11-27-2004, 12:50 AM | #10 | |
11-27-2004, 01:18 AM | #11 |
67-72 Addict!
That stance looks perfect for me. Where did you get your lowering coils?.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
11-27-2004, 01:33 AM | #12 |
the front coils came from gmc pauls and the rears came from outback truck parts (local place up in spring, tx) im still running the stock shocks
11-27-2004, 01:39 AM | #13 |
67-72 Addict!
Does it feel like you will need shock relocators or drop shocks or is it too soon to tell?. That is a huge improvemnet in that stance!
11-27-2004, 01:55 AM | #14 |
honestly i have no idea! eventually i would like to buy some kyb drop shocks and possibly relocate the shocks. it rides pretty well like it is though
11-27-2004, 02:09 PM | #15 |
GM ONLY BABY!!!
Dude, that passengers side door would look great on my truck. It would match perfectly.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-27-2004, 08:55 PM | #16 |
What kind of shifter are you using?? I love it!!
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
11-27-2004, 09:00 PM | #17 |
Truck looking real good Dinnut. It has a very nice stance to it, of course I like the stance before too!
11-27-2004, 09:01 PM | #18 |
the truck is an automatic. just to let you know. the shifter is a lokar piece. i love it. once i get the boot and everything on it will look even better. the shifter is the lokar hot rod curve one. http://www.lokar.com/ i really need to get the clutch pedal out of the truck to stop confusing people
11-27-2004, 09:11 PM | #19 |
I knew it was a auto shifter. Wasn't sure if it was a Lokar though. How do you like it??
11-27-2004, 09:16 PM | #20 |
i love it. its a little bit interesting to install with the tranny still in the vehicle though... the first time we installed it we got lucky and i had a big hole in the floor from my old shifter and that made things easier.... other than that it is great!
11-27-2004, 09:18 PM | #21 |
Can you install it on a tranny already in the truck??
11-27-2004, 10:14 PM | #22 |
Got Light Emitting Diode?
they just clamp on to the tranny except for two bolts that you have to pull out of the tail to bolt it on. do you like it that tall??? i got a shorter one and i love it. get lots of complements.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
11-27-2004, 11:55 PM | #23 |
SLOW BUT SURE,BUT CLOSER
Lookin' great!!!!!!!
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... |
11-28-2004, 12:09 AM | #24 |
MY EX DRIVES A BROOM
68w/sbc406,
where did youet the cup holders, and how did you install them?
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
11-28-2004, 01:37 AM | #25 |
maybe its just the way my truck is setup but it was a pain to get all that lined up and bolted in....
