Mike
HEI problem?
Last night,coming home,it felt like my trans was slipping.The truck kept surgeing.When I went out to check it,the truck wouldn't start.I have not checked for spark yet.Will a bad module cause a problem like this?I only had them run or not run.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
![]() Join Date: May 2002
Yep--sure will. So will the pickup coil under the rotor--look for missing insulation on the tiny wires to the pickup. I had one of these little wires break completely but would still make occasional contact and run--talk about something driving you crazy!
Stepsides look like real trucks! Smitty ![]() |
![]() Join Date: Apr 2000
Check your gas filter.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Mike
The starting part was the module.It just went out at the same time I was having trans problems.The truck goes in monday to have the trans rebuilt/repaired.Just glad it is under warranty.
