Old 01-05-2005, 01:18 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
Sway bar and air dam????
I bought a sway bar from Buffalo Elk for my 77 Cheyenne. He delivered it to Stoked Out Specialties for me today. They held it up to my truck, and it looks like the air dam will have to be removed for the sway bar to fit.
Does any one have a front sway bar and the plastic air dam on their truck? I need some pics to see how this works....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-05-2005, 01:36 AM   #2
low 84
low 84's Avatar
mine had both the bar and the air dam when i bought it. i can't see why they would interfere. the airdam bolts to the bumper and the swaybar to the frame horns and lca's.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-05-2005, 01:40 AM   #3
low 84
low 84's Avatar
i just looked at the pics of your truck and i have never seen an air damn like that. mabey its only on 73-80's, the 81-87 ones bolt to the bottum of the bumper
'05 1500 Crew Cab
RIP
Old 01-05-2005, 06:30 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Look carefully and you can see the sway bar mounted on my truck.
I don't see how it would not fit.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-05-2005, 09:52 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, it looks like I need to be more specific about my request. Since it's a 77 the air dam is mounted behind the bumper. I need pics from someone with a 73-80 truck....
Old 01-05-2005, 11:51 AM   #6
RockHQ
ROCKET POWER!
RockHQ's Avatar
I have a swaybar+the hideous 73-80 airdam. Short of the swapped engine the truck has an amazing amount of factory issue parts (and all of them need to be replaced ).
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 01-05-2005, 01:29 PM   #7
Russell
Professional Grade
Russell's Avatar
I'll snap some pictures when I head back to school and post them when I get home
My air dam is all busted up unfortunately =/
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-05-2005, 05:08 PM   #8
bluex
bluex's Avatar
Anyone have pics of how the sway bar mounts? I got one on the way too and was wondering if I'm gonna have to drill the holes or should they be there? Its going on a '78 heavy half, I think he said the bar is from an 81 its a 1 1/16".
bluex is offline   Reply With Quote
Old 01-05-2005, 06:27 PM   #9
78SilveradoSWB
78SilveradoSWB's Avatar
The holes to mount the swaybar should already be there. See attached picture. Mounts to brackets mounted to LCA and frame support.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 01-05-2005, 06:47 PM   #10
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I had to buy the mount that goes between the bushing and the frame. If your truck was not originally equipped with a swaybar, you will not have the mounts. I bought mine from the dealer because the factory mounted them with rivets. I decided not to try to remove rivets in a junkyard setting. As someone else said, the holes for everything were already there.
It looks like N2TRUX is missing two of the bushing mounts. It should have 4. Two for the frame and two for the LCA.
Go ahead and replace the bushings when you install it. I think they were $3.99 a pair at Auto Zone for poly bushings, so there is little expense involved.
Oh, and adding the swaybar will make an amazing difference in how the truck handles.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-05-2005, 08:10 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Russell
I'll snap some pictures when I head back to school and post them when I get home. My air dam is all busted up unfortunately =/
Russell that would help a lot.
bluex- Yes the 1/2 tons are 1 1/16" and the 3/4 tons are 1 1/25" which is what I have now.
Slonaker- I have a complete bushing set with clamps from PST that I didn't use on my Blazer suspension rebuild. It's a 1 1/16" set so I don't know if I can make it work or not. If it won't I'll just buy new ones.
Old 01-05-2005, 09:05 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Not trying to jump topics,... But I have a "new" pre-'81 air dams if someone needs one. Just send me a PM.
Keith
Convert to disc brakes.
Old 01-05-2005, 10:24 PM   #13
78SilveradoSWB
[QUOTE=N2TRUX]Russell that would help a lot.
I think it should be 1.25" ( 1 1/4") and not 1 1/25"
Mitch
454 BB, TH400
Old 01-05-2005, 10:50 PM   #14
Russell
Professional Grade
Russell's Avatar
Here we go!
Check out that tasty salt!! And yes, I know the bushing fell off the bar, my truck squeaks like crazy becuase of that, just been too lazy to put the bushing back on...
The dam is gonna come off pretty quick, It is broken, and the tire rubs it when I turn sharply to the right.
Old 01-06-2005, 12:00 AM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
.....I think it should be 1.25" ( 1 1/4") and not 1 1/25"
I knew when I typed that it didn't look correct. Yes, that is "supposed " to be 1.25"
Russell-Thanks for the pics. Since I can't be where my truck is that helps a lot. From what the guys at Stoked Out were seeing, they felt sure the air dam had to be removed to clear the sway bar. It appears that looks are decieving ...
Now get your bushing back in place....
Old 01-06-2005, 10:14 AM   #16
eagle23
Active Member
Just pm'd you.
eagle23 is offline   Reply With Quote
Old 01-06-2005, 05:02 PM   #17
bluex
bluex's Avatar
It just so happens I'll need a set for my 1 1/16 bar if you want to sell them. Just LMK and I'll be glad to take them off your hands.
So theres no brackets at the LCA other than the ones around the bushing, and two brackets that attach the bushing to the frame. Those two are coming with my bar but one is bent up, anyone have the part numbers for them handy??
Thanks for the help guys.
Old 01-06-2005, 09:58 PM   #18
lolife99
lolife99's Avatar
Pre-'81 air dam
Here's a pic of one, off the truck. I believe they are still available from GM. Also I think there use to be a 2wd,... AND a (taller) 4wd version.
Keith
Old 01-07-2005, 11:04 PM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Ok, now I have a new question for an old thread. Does anyone know the answer to this-
I just read the thread that Tx Firefighter posted in the FAQ forum about Early Classics Front Sway Bar Frame Mount Brackets for lowered trucks. I went to Early Classics website and discovered they only make these to fit 63-66 and 67-72 trucks.
I know you can put a 73-87 crossmember under a 67-72 frame so I "assume" the sway bar mounts are the same too. Can anyone verify this to be true? Has anyone used a 73-87 sway bar set up on their 67-72 frame?
Old 01-07-2005, 11:30 PM   #20
lolife99
lolife99's Avatar
yes
N2TRUX,... I had the ECE mounts on my old '82 2wd Blazer. I had ordered them for my '71 swb project,... but decided to use them when I lowered the blazer front end. Sorry, but I don't have any pics.
Keith
Old 01-07-2005, 11:33 PM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
lolife99 that's what I needed to know. I "assumed" they would work just fine, but I wanted to be sure before I ordered a set. Thanks for the info....
BTW- Do you have "any" pics of your 82?
Old 01-07-2005, 11:36 PM   #22
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Those two grease zerks pointed straight down look like they are going to be in serious danger of getting whacked off on the first thing that hits them.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-09-2005, 12:06 AM   #23
lolife99
lolife99's Avatar
Pics for N2TRUX,...
I had to scan some crappy old photos. This is all I have. The pics make it look better than it actually was. It needed rockers, quarters, and more power under the hood. Still made a nice beater. Sold it for $3400.00. Kinda wish I had it back!
Keith
Old 01-09-2005, 12:24 AM   #24
lolife99
lolife99's Avatar
Ken,... I almost for got. CONGRATS on the magazine feature! I will have to add that one to my collection. lolife99.
Keith
Old 01-09-2005, 12:44 AM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Ken,... I almost for got. CONGRATS on the magazine feature!.
Thanks! I'm pretty proud of the coverage I got. At least what I "hear" I got, since I haven't seen it yet.
The red paint does hide a lot. The pics make your Blazer look great. I bet you do wish you had it back, but you still have another sweet Blazer. I cleaned your pics up for you....
