Old 04-13-2005, 07:33 PM   #1
Sooner1970_K10
1970 K10, 350, 4spd!
Sooner1970_K10's Avatar
Glovebox/CD player Installed *Pics*
Well not many commented on the glovebox I had made. I am very happy with the way the box turned out. Here are some pictures of everything installed. It wasnt as cheap as just cutting a hole in the dash but in 30 mins I could have the truck back to stock
P.S. Yes, I know I forgot to connect the drivers side vent hose back up. While I had everything torn out I cleaned and wiped down all the duct and the inside of the unit that hangs down below the dash.
Sooner1970_K10 is offline   Reply With Quote
Old 04-13-2005, 07:37 PM   #2
Sweet72
Sweet72's Avatar
Super clean install man! Looks great. Improvement without defacing the OldSkoolness of these fine machines.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 04-13-2005, 07:53 PM   #3
Very nice. Does it have a remote or do you have real long arms (like me)?
Old 04-13-2005, 08:01 PM   #4
Sooner1970_K10
That was one of the requirements of the cd player. I bought one with a remote.
Old 04-13-2005, 08:06 PM   #5
69 Short Fleet
Looks very nice, I'm going the same route (glovebox), just waiting for the head unit to arrive in the mail. I still am undecided on where the speakers are going though.
69 Short Fleet is offline   Reply With Quote
Old 04-13-2005, 08:33 PM   #6
Sooner1970_K10
What size speakers did you get? I have (2) 4" Alpines in a custom wood bracket I made that fit perfectly into the spot that the stock 4 x 10 came out of. Keeping with the theme of not cutting the truck up, I plan to try and fabricate some type of box that will fit down near the bottom of the floor shifter.
Old 04-13-2005, 09:35 PM   #7
Low69CST
You stole my idea! I've wanted to do that along with put a bunch of extra guages, torque converter lockup control, data aquisition link (way down the road). What did you make that box out of? Did the radio have clearance problems with A/C box? Same as you again I want to put the speakers down on the floor so I don't cut up the cab. I'd like to see some pics if/when you get started on that.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-13-2005, 09:39 PM   #8
ezernut9mm
ezernut9mm's Avatar
will the remote get through the glove box door? or do you have to drive with it open??? ;-)
'06 silverado (daily driver)
'02 nissan sentra (wal-mart warrior)
ezernut9mm is offline   Reply With Quote
Old 04-13-2005, 09:53 PM   #9
Sooner1970_K10
I am stealing the idea to install an infrared repeater from another board member. From what I understand it has to have power or something but its a very then LED wire that can run from outside the glovebox to inside the glovebox so I can use the remote with the glovebox door closed. I really have no clue what I am talking about, just the theory or concept of the idea. Will get more information on the subject in the near future.
Old 04-13-2005, 09:58 PM   #10
ROBBY WHITE
ZOIE AND ZACK
ROBBY WHITE's Avatar
man that looks good super clean!! any reason you chose right hand corner of glove box? most of the ones i've seen are in the middle. are you going to mount any thing else next to it? do you have any pictures of speaker bracket you made.
AMERICAN BULLDOGS AND CHEVY TRUCKS
71 1/2 SUBURBAN 402BB IN PROGRESS
90 1/2 TON SILVERADO
02 1/2 SUBURBAN
67 GMC 1/2 TON LONGBED
05 AVALANCHE
ROBBY WHITE is offline   Reply With Quote
Old 04-13-2005, 10:02 PM   #11
jamis
F.A.S.T. president
jamis's Avatar
thats a very clean job
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 04-13-2005, 10:04 PM   #12
Sooner1970_K10
The box was made out of 20 gauge galvanized steel. The reason the cd player is shoved way over on the passanger side of the glovebox is because of the riser that comes off the A/C box. The glovebox is 2 1/2 inches deep. The cd player is around 6 1/2 inches long. There is around 1/4 inch to 1/2 space above the a/c box and the same amount below the slant of the firewall.
I was actually looking this evening and I might attempt to make a bracket that is slighty below and setback from the face of the dash, that would hold (2) 6 1/2 speakers. I like making things out of wood! hah, my grandpa was a woodshop teacher for years and years. He has an airconditioned wood working shop that is about the size of my house.
Old 04-13-2005, 10:10 PM   #13
Sooner1970_K10
The reason I placed the cd player in the right hand corner is because the cab has A/C and that takes up the whole left side behind the box. I couldnt even place cd player in the center from top to bottom because of the depth of the cd player would have hit the slant in the firewall. The only space in my glovebox area that would fit the cd player was the bottom right.
Old 04-13-2005, 10:13 PM   #14
ROBBY WHITE
ZOIE AND ZACK
how about that speaker bracket any pics??
02 1/2 SUBURBAN
05 AVALANCHE
Old 04-13-2005, 10:14 PM   #15
69 Short Fleet
I still need to get the speakers, I'm looking at Pioneer's TS-D601P (6.5") & TS-D901P (6X9). How did you install the wood bracket for the 4" Alpines? Did you use the 2 factory bolt holes for the original speaker bracket and brace them in another spot also? The box idea (on the floor) is a good one. I've thought about installing 2 6.5" in the kick panels & 2 6 x 9's in the doors using baffles and dynamat but I gotta admit I'm pretty "chicken" about getting the jigsaw out (lol), I may go with pods (kickpanel)for the 6.5's and the box idea for the 6X9's (using fibreglass).
Old 04-13-2005, 11:41 PM   #16
Low69CST
Do you think the radio would fit in the top left corner instead of the bottom right? I had my plans with gauges lined across the bottom and radio uptop for looks. Just curious.
Old 04-14-2005, 10:04 AM   #17
Yukon Jack
Yukon Jack's Avatar
I've never seen a a/c equipped truck's glove box to know how limited they are in size. Your setup looks real nice. Is there extra space that could be used to hold cd's in the glove box if the box you made was modified.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-14-2005, 10:29 AM   #18
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Nice install. I did the same to mine. Keep us posted on the IR repeater thing. Also, I found I had to install a little fan in the glovebox to keep the unit cool. I put an antennea splitter on so i could run cd receiver and stock am radio off same antennea.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 04-14-2005, 02:50 PM   #19
Lemield
Lemield's Avatar
Looks really nice! Great job.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 04-14-2005, 10:25 PM   #20
Sooner1970_K10
I wanted the metal mounting bracket that held the wooden speaker bracket to be extremely heavy duty. I didnt want to have it jar loose and have to tear the glovebox and vent hoses back out to re-adjust the speakers. I probably went way to far over-board but I made a steel framed bracket out of 1/8" thick steel square 1/2" tubing. It uses the factory bolt slot for mounting and just barely squeezes in up behind the A/C vent above the stock radio and the factory mounting bracket that is mounted on the firewall.
Old 04-14-2005, 10:32 PM   #21
Sooner1970_K10
Simple answer, No.
Overall the glovebox width is around 18 1/2". On an A/C truck the A/C riser eats up 7 inches from the drivers side of the glovebox towards the middle. That leaves you around 11" to work with. I dont know exact measurements from the top of the glovebox to the firewall but I would guess its around 5". My cd player is 6 1/2" deep so it would have no chance to fir in the top left corner. Maybe if you removed your glovebox door and built the glovebox more shallow than mine which was 2 1/2" you might be able to fit a cd player in the top left of a non-a/c cab. More than likely the cd player would have to stick out a little past the front of the dash to fit.
Old 04-14-2005, 10:38 PM   #22
Sooner1970_K10
I thought of having a little cubby hole on the drivers side of the cd player inbetween it and the A/C hose but it all boiled down to money, time and looks. My cd player is around 7 1/2" wide, with the 1 5/8" I left on the passanger side of the cd player to match the 1 5/8" on the bottom of the cd player, you would have about 2-3 inches of space. You would have almost enough depth so that you could stand a couple of cd cases in the upright position in a small shelf in the glovebox. Also on top of the cd player, you could make a shelf that was around the same width as the cd player and be 2-3 inches high and be able to go back far enough you could probably store a couple of cd cases laying down.
Old 04-14-2005, 10:59 PM   #23
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
nice and clean
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 04-15-2005, 04:22 PM   #24
67chevemall
67chevemall's Avatar
Very smooth! Now you just have to take the remote receiver out of the face plate and
mount it down below so you can keep the door shut! J/K
Good job.
67chevemall is offline   Reply With Quote
Old 04-15-2005, 05:26 PM   #25
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
where is the repeater you were talking about?????
Joel
joelboxt is offline   Reply With Quote
